Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Excella > 1990 - 1993 Excella
Old 11-06-2007, 04:58 PM   #1
firedog
firedog's Avatar
Profile:  1992 29' Excella
Lowell , Massachusetts
Rivet Plate Light Out
Hi, I replaced the bulb, with a #168, looks same as old one , still no plate light,any ideas? Thanks John.
1992 Excella 29, Classic Owner.http://www.wbcci.org/
firedog is offline   Reply With Quote
Old 11-06-2007, 05:22 PM   #2
RBolton
RBolton's Avatar
Profile:  Belington , West Virginia
Check the socket with a test lamp if you have one to make sure that you have power. If so, check your ground. There may be a separate ground wire or the lamp may just ground to the body of the trailer. If that is the case, try tightening the mounting screws.
RBolton is offline   Reply With Quote
Old 03-13-2008, 07:17 AM   #3
firedog
firedog's Avatar
plate light
Gee thanks,the ground always causes problems.
Light or light cover over the door.. help please! harestream Lights - Interior & Exterior 19 08-29-2008 09:51 AM
Scare light and marker light won't work??? shinybean Lights - Interior & Exterior 12 02-12-2007 08:51 PM
Can't light furnace pilot light? (again?) Matthew&Gigi Furnaces, Heaters, Fireplaces & Air Conditioning 8 01-05-2005 11:52 AM
light globe/light covers David Hall Electrical - Systems, Generators, Batteries & Solar 5 02-18-2004 06:35 AM
Tradewind name plate Don Tucker Parts Archive 2 09-30-2003 11:35 AM
