Old 04-19-2017, 08:09 PM   #1
1991 25' Excella
Chino Valley , Arizona
Need Help to remove exterior doorhandle and lockset
I am at a loss as to how to remove the exterior door handle and lockset so I can repair the Schlage lock. The lock turns/spins but doesn't engage the deadbolt. On the inside is a thumb latch knob that I can remove but there is no access for removal of the screws that attach the exterior handle to the skin.
If anyone has advice I would appreciate hearing from you.
Aznomad450 is offline   Reply With Quote
Old 04-20-2017, 05:20 AM   #2
64airstream's Avatar
1964 22' Safari
1968 26' Overlander
Beaver County , Pennsylvania
AZ,
Welcome to the forums.
Sometimes previous owners will change out locksets. I'm not sure if yours is original or changed. If you can post a photo or two of the handle and lock, I bet someone here will be able to help. You can add a photo by clicking on the "Manage Attachments" button, selecting, then uploading a photo. Sometimes you have to first downsize the photo in your photo program so it fits.
Roy and Marie
64airstream is offline   Reply With Quote
Old 04-25-2017, 08:48 AM   #3
1991 25' Excella
Schlage Lockset and exterior door handle
Thank you for the reply to my post. The interior panels are untouched so I doubt this has ever been removed before. The key works and spins the lock but it does not engage the deadbolt. At this point it appears that my only option is to take a hole saw and do a shallow cut to remove the interior tin and expose the screws from the backside.
Old 04-25-2017, 09:05 AM   #4
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
You need o remove the interior skin to access the back of the lock and handle.
mayco is offline   Reply With Quote
Old 04-25-2017, 09:13 AM   #5
HowieE's Avatar
Princeton , New Jersey
Images: 12
To remove the door handle without removing the interior skin panel you can cut a small hole in the inside skin just behind the points that the handle attaches to the trailer. This gives access to the 2 bolts. You will have the wires for the door bell at the lower hole so don't just yank the handle off.
Once your have made the lock change and reinstalled the handle you can cover the holes with standard 2x4 flush electric box covers. Sorry i can not post a picture to help as i have reached the limit for posting pictures.
I you send me a PM I will send a picture of the finished product..
2004 Excursion 4x4
HowieE is online now   Reply With Quote
Old 04-25-2017, 10:10 AM   #6
1991 25' Excella
Thank you for the confirmation. There is literally 3 inches between the door frame and the window, I have a piece of the interior panel that the manufacturer left in a storage area for 26 years. I think I will hole saw the panel and remove the handle then cut a patch out of the material I found and pop-rivet it in place to cover the holes. The interior thumb latch is already attached using a piece of the same material ~ presumably from the factory.....
Old 04-25-2017, 07:16 PM   #7
1991 25' Excella
Exterior Door Handle Removal
Hi HowieE, the system won't allow me to submit a PM because I am not a trusted member.
Lockset and Deadbolt for '65 retronotold Doors & Locks 6 10-03-2010 01:23 AM
1958 flying cloud lockset help please. . ddstech Doors & Locks 7 07-08-2010 03:51 PM
need door knob/lockset '61 Overlander 61Overlander Doors & Locks 1 12-01-2003 11:59 AM
'61 door lockset repair/replace 61Overlander Doors & Locks 5 08-23-2003 07:33 PM
vintage door hardware/lockset 61Overlander Doors & Locks 0 08-21-2003 08:04 PM
