Old 04-13-2014, 03:10 PM   #1
Dickandvicki's Avatar
1991 29' Excella
Tulsa , Oklahoma
Help.. Can't find the LP detector
We are fairly new to Airstreaming and we need help..
I was just wondering if there is anyone out there that can help me find my LP detector on my '93 Excella Classic? We want to replace it with a new one. I called Airstream and they assured me that all AS come with one.. They said it would be someplace near galley. I have looked high and low and I can't seem to find it.
Vickie
Dickandvicki is offline   Reply With Quote
Old 04-13-2014, 03:40 PM   #2
RamblinManGa's Avatar
2016 28' Pendleton
Scottsdale , Arizona
Hi from AZ. . . just aft of the galley, just above floor is where both of ours are in a Safari & Flying Cloud . regards, Craig
WBCCI 2851,4CU
RamblinManGa is offline   Reply With Quote
Old 04-15-2014, 07:36 AM   #3
voxmaestro's Avatar
1990 25' Excella
Foley , Alabama
Send a message via Yahoo to voxmaestro Send a message via Skype™ to voxmaestro
On my 1990 25' CB Excella, it is located just to the left of the entrance door at the bottom of the cabinet which houses the gas range and furnace. It faces the living area.
voxmaestro is offline   Reply With Quote
Old 04-15-2014, 07:53 AM   #4
1987 25' Sovereign
Oregon , Ohio
Same in our 87 25' Sovereign.
msmcv51 is offline   Reply With Quote
Old 04-15-2014, 08:03 AM   #5
jkcru's Avatar
2010 28' Flying Cloud
Escondido , California
Perhaps the PO removed the detector, I would look for a caped wire(12 volt) in the areas suggested, probably enclosed in a removable panel.
jkcru is offline   Reply With Quote
Old 04-15-2014, 01:12 PM   #6
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
In the big units the detector is hard wired in the hallway below the cedar closet.
Old 04-15-2014, 02:08 PM   #7
Wise Elder
Jammer's Avatar
2010 30' Classic
Well you could always spray some hairspray around. Or eat a can of beans and wait.
Old 04-15-2014, 03:08 PM   #8
LeeJ's Avatar
1985 25' Sovereign
Okc , Oklahoma
On my 85 25' Sovereign it is on the wall opposite the range and door
Lee Johnson
Corriente de Aire
85 Soverign
LeeJ is offline   Reply With Quote
Old 04-15-2014, 05:23 PM   #9
airdreamers's Avatar
2008 27' International FB
Venice , Florida
Images: 14
Welcome to the forum LeeJ. As yours, my detector is located over the TV shelf street side behind the curtain.
Bill and Janice, We're lovin' it! (Airstreaming)
Airdreamers
WBCCI #8880
AIR #41310
airdreamers is offline   Reply With Quote
Old 04-15-2014, 11:18 PM   #10
voxmaestro's Avatar
1990 25' Excella
Foley , Alabama
If you are in the position of selecting a location for the detector, bear in mind LP gas is heavier than air and a location near the floor will alert you sooner to a possible leak.
Old 04-16-2014, 05:07 PM   #11
1991 29' Excella
Tulsa , Oklahoma
Good grief, I have looked everyplace I can think of and all the places you have all mentioned and still can't find the LP detector. I had planned on replacing it once I located it and saw the configuration. When I called Airstream the indicated that all AS come equipped with one. But geeze I can't find it or anyplace that looks like it could have been.
I want to thank everyone for their suggestions of where to look.. We are camping now and I'm keeping the LP turned off except before showers just to be safe.
Guess I'll just shop and install a new detector and try to find a good place to install it.
Once again I want to thank all you Airstreamers for your help.
Vickie
Old 03-06-2015, 01:31 PM   #12
1990 29' Excella
baltimore , Maryland
Ok..
Come in the front door. Make sure you trip on your way in. Stumble to the far wall and fall in head first really hard. When you regain consciousness and wake up on the floor face down, turn your head to the left. It should be right there.
groundhogy is offline   Reply With Quote
Old 06-08-2015, 03:03 PM   #13
1991 29' Excella
Tulsa , Oklahoma
I looked over every inch of my AS, even took it into an AS expert. He looked too. Finally had him install one...
Trying to find Grandpa's Old Airstream...can I find it with Serial Number?? Jakescheid Our Community 13 11-22-2011 11:01 AM
I give up... Can you help me find these parts? TPdrums Interior Restoration Forum 4 02-21-2009 03:24 PM
Help! Where can I find the nutone food processor? cmgirdwood Nu-Tone Appliances & Central Vac System 8 02-04-2004 10:23 AM
Can Not Find Leak Help! Rennegarbe1 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 10 05-12-2003 04:08 PM
