Old 07-03-2014, 11:00 AM   #15
John&Vicki's Avatar
1990 25' Excella
Sisters , Oregon
We would like to remove the wallpaper in the bathroom. I've searched here and discovered the following methods: heat gun; steamer; Diff; vinegar and water. Anyone have experience with this and have something you recommend?
Poppy
John & Vicki
WBCCI #4291
Grown men don't need leaders. ~ Edward Abbey
John&Vicki is offline   Reply With Quote
Old 07-03-2014, 11:05 AM   #16
John&Vicki's Avatar
1990 25' Excella
Sisters , Oregon
Full of questions today...
Has anyone mounted a Fiamma bike rack on their late 80's, early 90's era Excella?
Poppy
John & Vicki
WBCCI #4291
Old 09-11-2014, 10:49 AM   #17
cramar
1992 25' Excella
Leamington , Ontario
We have a 25' 1992 Excella which we are currently upgrading. Twin bed of course. I'm disappointed in the lack of storage for larger items like folding cars, tables, outdoor mats, etc.
Boomerstream One - Live Riveted!
Leamington, ON
Canada
cramar is offline   Reply With Quote
Old 09-11-2014, 12:41 PM   #18
John&Vicki's Avatar
1990 25' Excella
Sisters , Oregon
I installed two recliners in place of the gaucho and modified the cabinet in front of them in order to move the large table aft. To my delight two Airstream folding chairs fir into the modified cabinet perfectly.
John
John & Vicki
WBCCI #4291
Old 09-11-2014, 12:42 PM   #19
John&Vicki's Avatar
1990 25' Excella
Sisters , Oregon
Picture of the recliners:
John & Vicki
WBCCI #4291
Old 09-11-2014, 01:12 PM   #20
Dickandvicki's Avatar
1991 29' Excella
Tulsa , Oklahoma
I love your new recliners! What a nice upgrade!
Dickandvicki is offline   Reply With Quote
Old 09-11-2014, 01:19 PM   #21
John&Vicki's Avatar
1990 25' Excella
Sisters , Oregon
Thanks! They were part of seating that I had on hand in my home theater. Turned out to the perfect size and color - and I love the leather smell. Here's another picture with the table stowed (hadn't patched the floor yet):
John & Vicki
WBCCI #4291
Old 09-11-2014, 03:39 PM   #22
1993 25' Excella
CLeveland , Ohio
We have a 1993 25 foot Excella with rear twin beds. We purchased it in April and have put in more work into then anticipated. Rotted floors under the beds made us take out the back portion of flooring. Water poured down the sides through the rivets when it rained. We have sealed up the sides, used eternabond on the roof to cover seams and rivets and hopefully will finish in a month or so. We also had the furniture reupholstered by an Amish man for under 400 dollars and he did an excellent job!
Akronguy is offline   Reply With Quote
Old 12-16-2014, 05:09 PM   #23
Bonners Ferry , Idaho
wcanadian60
We are looking at a 1992 25 ft Excella, we have been looking for over a year and the ones we have looked at all had some floor rot, does anyone have any idea what sort of cost is involved to replace the bedroom floor, and is it possible to DIY.
We have a 2014 Silverado 1500 that were going to use as a tow vehicle, do you think that is big enough..
wcanadian60 is offline   Reply With Quote
Old 12-21-2014, 06:06 PM   #24
1993 25' Excella
CLeveland , Ohio
My wife and I did it ourselves and I would say it cost a hundred for the wood, 20 dollars for a quart of POR15, another ten for the original screws from the vintage airstream parts place (can't remember the name offhand) . It took some time to get the old wood out of the c-channel, but it can be done.
Old 12-25-2014, 10:44 AM   #25
cramar
1992 25' Excella
Sounds like exactly what happened to me. But it cost me over $300 in material and 3 weeks of full-time effort with my wife helping to fix the subfloor. The main expense was two sheets of 3/4" (couldn't get 5/8") marine-grade plywood at $100 a sheet. Plus a couple of sheets of rigid-foam insulation for the bottom of the subfloor. As mentioned, getting all the OSB out of the C-channel was a time consuming pain. Even worse was getting the new plywood installed. Cardboard templets had to be made and since 3/4' plywood wouldn't fit into the C-channel, the edges of the plywood had to be routered with a bevel to fit. Then I had to cut the plywood into a mosaic since I couldn't get the bigger pieces into place. All this was very time consuming. Plus sanding and painting the frame of course, and re-caulking the outside of the trailer.
Some pictures (including lounge-chairs for others' interest) are shown here:
http://www.airforums.com/forums/f48/...-a-128413.html
Leamington, ON
Canada
Old 04-04-2016, 10:03 PM   #26
1993 25' Excella
Colville , Washington
I recently purchased a 92 Excella 25' with rear double bed. All of the cabinets appear to be original except for a plywood panel attached just above the floor under the range. Please see my 3/21 new owner post. Does yours have a return air grill here to provide an air flow for the furnace blower? Thanks. Curt
CurtH93 is offline   Reply With Quote
Old 04-10-2016, 11:54 AM   #27
1991 25' Excella
Hartford , Wisconsin
I just purchased a 25' Center bath, rear twins. Excella 1991
It does need axles, and tires otherwise in pretty decent shape. The P.O. had an AS dealer install disc brakes in 2007. When I am ready to tackle the axles, I'll start a thread about it.
One thing I do need for it is, a rear bedroom side window sash. Measures 22" X 18-1/4" on outside of aluminum frame around glass. I have a parts inquiry into AS in Ohio. I stumbled across info for Colaw salvage, will give them a call.
I am really happy with the purchase, and am enjoying learning about it.
TOPORANGER is offline   Reply With Quote
Old 05-01-2016, 10:25 AM   #28
1990 25' Excella
Tucson , Arizona
Hi John & Vicki,
Painted my bath right over the wall paper with a shower & bath paint from Home Depot.Took several hot showers & no problem.Looks great.Used fusion spray paint for all the plastic.
Have a question for you. How does your fridge work in the heat of the day?Mine drops in temp quite a bit. 50-55 degrees.
I have the exact same unit you have.
Love it!
Ray
winston10 is offline   Reply With Quote
1988 Excella 32' GVWR Confusion! Rob&Julie Towing, Tow Vehicles & Hitches 26 03-17-2012 02:06 PM
Esmerelda the 1992 Excella 29' LawChick 1990 - 1993 Excella 59 02-15-2012 09:36 PM
Excella Info? M Williams 1981 - 1983 Excella 4 01-26-2011 07:13 PM
