Old 07-25-2018, 09:02 PM   #1
1997 25' Safari
1973 25' Tradewind
Greenville , South Carolina
Leak at check valve or water pump.
Has anybody else had a leak at their pump and check valve connections? On our last trip we came back to camper to find wet carpet surrounding the area to pump. We ripped up carpet and padding to let it dry but I have gotten started on repairing it. Any suggestion on where to start. Should I put pressure hose to line and look for leak? Might be check valve?
I have a 97 Safari.
Thanks any help.
RickClick image for larger version
ID:	318032Click image for larger version
montanablue is offline   Reply With Quote
Old 07-25-2018, 09:47 PM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Not sure what you are describing as a "check valve".
Most pumps have internal check valves.
The device on the left side of the pump looks like an inline strainer.
Perhaps the screw on cap has worked loose.
Old 07-26-2018, 06:16 AM   #3
1997 25' Safari
1973 25' Tradewind
Thanks for identifying the strainer if that is what it is. I just figured it was a check valve.
My question would be do these leak? I will disconnect, clean and reconnect to see if that was issue. Second question would be be to put air pressure in line and dab soapy water to look for leak.
Any suggestions?
Rick
Old 07-26-2018, 06:28 AM   #4
sandlapper's Avatar
1993 34' Excella
York , South Carolina
Rick, I have replaced several pumps over the years, they tend to develop leaks. If yours is the original it could have given up. As suggested check the fittings around the pump, they can loosen from vibrating during use and bouncing down the road. Good news is they are not terribly expensive, is an easy change out, and can be purchased most any RV/marine store.
Put pressure to it with water and look for the source. Good luck.
John
John
WBCCI #268 Palmetto State Airstream Club 22
Region 3 President....come with us, you will like it.
Go often to the house of a friend, for weeds choke the unused path........Emerson
Are you kind?
sandlapper is offline   Reply With Quote
Old 07-26-2018, 06:59 AM   #5
1997 25' Safari
1973 25' Tradewind
Thanks John I will look at fittings and clean the strainer too. Looking for forward to fall gathering.
Old 07-26-2018, 07:35 AM   #6
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
The strainer is on the suction side of the pump. You will not be able to pressurize it with the pump.
Old 07-26-2018, 08:19 PM   #7
2019 25' International
Washington , Washington, D.C.
If your water pump is close to where your city water outlet is, be sure and check / tighten those fittings as well.
PatLee is offline   Reply With Quote
Old 07-29-2018, 01:13 AM   #8
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Where is pump wet? Has this pump ever frozen? I replaced ours with a REBEL pump!!! We my goodness!! This is a proper pump!
I found some loose PEX fittings and replaced them. Some piping had to be moved... 30 minutes...
I am running a better power supply wire and switches when we get home.
Peace and Blessings..
Channing
WBCCI# 30676
Old 07-29-2018, 07:58 PM   #9
1997 25' Safari
1973 25' Tradewind
Well I finally got the time to remove the pump with strainer. Detached the strainer and see there is a small cracked part off of the strainerwhich is used to lock it down. It did feel firm when taking strainer apart. Strainer was not clogged.
So my first step is to replace strainer with new, but I see that thus model #170 Is no longer available unless somebody can point me to one. I found this one on EBay. Can some tell me if this one is a mtch replacement?
https://rover.ebay.com/rover/0/0/0?m...2F291427376378
Thanks everybody.
ID:	318375Click image for larger version
ID:	318376Click image for larger version
Old 07-29-2018, 08:54 PM   #10
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Looks like it will work.
While you have it apart.
I would get rid of the hard piping in and out of the pump. Use something flexible
Makes for a somewhat quieter pump.
More importantly it reduces the stress on all parts involved.
Old 07-29-2018, 09:03 PM   #11
1997 25' Safari
1973 25' Tradewind
Thanks for the suggestion but I am not sure what you are referring to as hard piping. It has pex in and out. Please expand.
Thanks, Rick
Old 07-29-2018, 11:58 PM   #12
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
the strainer is on the 'suction' side of the pump... it can leak.... so, if strainer was cracked, I think the pump body might be compromised... especially if the water leaks when pressure is in the system.
Also... there is water pressure at the pump when City water is providing pressure... so you are aware... you can't really test the system for leak repair without having pump connected from the water system.
Channing
WBCCI# 30676
Old 07-30-2018, 12:15 AM   #13
2007 22' International CCD
Thanks, Rick
PEX is not as stiff as copper for example, but it is stiff enough to transmit vibration. Camco makes a set of flex pipes that are reinforced tubing that flexes easily. That will reduce transmitted noise.
Old 07-30-2018, 08:33 PM   #14
1997 25' Safari
1973 25' Tradewind
I bought a new strainer today. Went to I stall it and found the Pex 90 degree elbow may be damaged. It looks like you can see some portions of the connector which fits inside is jagged. I am wondering if is something I should change out as well. Opinions? Also, any reason to use to use tehplon tape when re-connecting pump, strainer and Pex lines?
ThanksClick image for larger version
ID:	318475Click image for larger version
Old 07-31-2018, 06:16 AM   #15
sandlapper's Avatar
1993 34' Excella
Rick, the connector looks fine to me. Maybe a bit of residue in there but otherwise OK.
I use both Teflon and plumbers dope on all screw- on connections. Water is thin and can be difficult to manage sometimes, especially under pressure. Hand tighten the fitting, no pliers.
John
Are you kind?
Old 07-31-2018, 01:40 PM   #16
2007 23' Safari SE
Annandale , New Jersey
Recently replaced my shurflow water pump since I believe the check valve was leaking and the pump once turned on would never shut off. I did the entire check of the plumbing and found no leaks.
When replacing it, the shurflow replacement (revolution?) was not an exact replacement and it looked as if some work was needed on moving pex connectors. I then recalled that I also had ordered the silencing flexible pipe attachments and not only do they quiet the pump lines vibration, they are fanstastic to ensure a flexible connection, even allowing me to move the pump to a more accessible location.
The biggest challenge was getting the screws off the back/blind side. In the 23D, you really cant get much leverage and ended up stripping one of the philips heads. Luckily while trying to see if i could get a hacksaw blade under it to cut the screw, I noticed that the pump was secured with rubber grommets/anti vibration feet. A simple lift of the pump freed it from the screw and with a channel lock, I backed it out. Works great now.
Fred L is offline   Reply With Quote
Old 07-31-2018, 08:26 PM   #17
1997 25' Safari
1973 25' Tradewind
Thanks all for suggestions. I plan to go forward with rehooking lines and making a test.
Black Tank Check Valve Leak ArcherTC Sprinter and B-van Forum 10 09-30-2017 10:19 AM
Should check valve leak a little? KYAirstream Plumbing - Systems & Fixtures 7 11-04-2012 11:09 AM
Bad Check Valve in Pump??? tinbender Water Heaters, Filters & Pumps 3 06-16-2011 07:56 PM
Today gate valve, later check valve. GlenCoombe Classic Motorhomes 1 09-20-2005 12:02 PM
Check , Check and Re-Check a new refer saga. thenewkid64 Refrigerators 13 06-24-2002 10:54 AM
