Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Safari > 1997 Safari
Old 08-09-2006, 10:29 AM   #1
csimingt
Profile:
LP alarm goes off periodically
Even though I have the LP turned off and I'm almost certain that I don't have an LP leak the alarm goes off periodically and then shuts itself off. The battery is fully charged and only 1 year old. Has anyone else experienced this problem. Can the LP alarm be changed out easily? By the way, I have the original 1997 Safari, but no one posts there!
Clark
csimingt is offline   Reply With Quote
Old 08-09-2006, 10:42 AM   #2
Safari-Rick
U.S.Navy Retired
Safari-Rick's Avatar
Profile:  2005 25' Safari
Lakewood , California
LP Alarm goes off
I had the same problem on my 05 Safari. All of a sudden in the middle of the night the alarm went off.
Have you tried resetting it?
Hold down the button on the face for about 10 seconds. If the button does not depress, then unscrew the plate and it should be on the back.
I've not had any problems since then.
R/
Safari-Rick
"Better to have more then you need, then need more then you have because you don't have enough!"
AIR #: 8129
Safari-Rick is offline   Reply With Quote
Old 08-09-2006, 10:45 AM   #3
csimingt
Profile:
Thank you, I will try re-setting the alarm.
Old 08-09-2006, 10:54 AM   #4
TIMEMACHINE
TIMEMACHINE's Avatar
Huntington Beach , California
similar problem
Hello,
I had a similar problem a couple of months ago. The alarm went off for no apparent reason and would not shut off even after pushing the reset button. Our AS was a month old when it occured and the only way to shut it off was to disconnect the hard wire going into the unit. I reconnected the wire and have not had a problem since. Like you, no gas was on and no leaks were present. I have no clue?
John
TIMEMACHINE is offline   Reply With Quote
Old 08-09-2006, 11:14 AM   #5
jcanavera
jcanavera's Avatar
Profile:  2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Clark
Just curious, is this an LP dector that you added? My '01 Safari only came with a smoke detector.
Jack
Jack Canavera
STL Mo.
AIR #56
'04 Classic 30' S.O.
'03 GMC Savana 2500
'08 Vespa GTS 250
Old 08-09-2006, 11:37 AM   #6
csimingt
Profile:
Although I bought the trailer in 1999, I am sure it was factory installed. It is located just inside on the right hand side of the doorway about 8 inches up from the floor.
Old 08-09-2006, 01:16 PM   #7
jcanavera
jcanavera's Avatar
Fenton , Missouri
Images: 143
Clark
Well they do now, I just moved your thread there.
Jack
Jack Canavera
STL Mo.
AIR #56
'03 GMC Savana 2500
'08 Vespa GTS 250
Old 10-26-2006, 09:00 PM   #8
ruberduk
Profile:  2004 28' International CCD
Ventura , California
Mine used to do the same thing. Now I think it's broken. It's stuck on red, nothing happens when I hit the test button, and even though it's on "alarm" there's no sound.
ruberduk is offline   Reply With Quote
S O S !!! luckydc Towing, Tow Vehicles & Hitches 3 04-18-2004 02:14 PM
Midland Weather Alarm Clock RoadKingMoe Our Community 12 07-07-2003 06:32 PM
Poll : What is your favorite ALARM when you're not in your A/S ? brunoffrance On The Road... 6 06-28-2003 04:34 AM
Security Alarm System for Airstream Richard Vroom Electrical - Systems, Generators, Batteries & Solar 3 06-15-2003 08:51 PM
