Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Safari > 1997 - 1999 Safari
Old 09-18-2016, 01:04 PM   #1
Buck944's Avatar
1998 25' Safari
Mascouche , Quebec
1998 safari front upper storage removal
Hi, is there someone that have remove the front upper storage on a 1998 safari? (Without destroying it off course. ..)
I can't find any hardware, wood screw or bolt holding that thing up there... or there is absence of gravity in there that prevent this storage to fall down???
My goal is to remove it and install instead a bunk bed...
Thanks all
1998 Safari 25' SS
2015 Toyota Sequoia Limited
Buck944 is offline   Reply With Quote
Old 09-18-2016, 01:05 PM   #2
Buck944's Avatar
1998 25' Safari
Mascouche , Quebec
This one
1998 Safari 25' SS
Old 09-18-2016, 02:24 PM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
If you don't find screws just inside the hinges of the doors I would loo to see if the end panels inside the cabinet, behind the speakers, can be removed to get to possible screws behind the speakers.
Is there a ledge just above the drapes over the window that could be taking the weight?
2004 Excursion 4x4
Old 09-18-2016, 03:01 PM   #4
Buck944's Avatar
1998 25' Safari
Mascouche , Quebec
Well... I finally had to pull harder... it look like this storage is the "core" of my six sleeper...
The storage was install with wood screw from the outside to the inside... I can't figure how they did that... I guess that this section of the roof was installed with the storage already on???
ID:	271926   Click image for larger version
ID:	271928   Click image for larger version
1998 Safari 25' SS
Old 09-18-2016, 03:01 PM   #5
Buck944's Avatar
1998 25' Safari
Mascouche , Quebec
I also found a mouse nest... Grrrr!
1998 Safari 25' SS
Old 09-18-2016, 03:02 PM   #6
Buck944's Avatar
1998 25' Safari
Mascouche , Quebec
Fyi
1998 Safari 25' SS
Old 09-18-2016, 03:21 PM   #7
HowieE's Avatar
Images: 12
Looks like they install the cabinet into the interior end cap before installing the end cap. A much stronger method and easy to do on a bench.
I like to see where that mouse could get to from there, what with the frame members.
2004 Excursion 4x4
Old 09-18-2016, 03:38 PM   #8
Buck944's Avatar
1998 25' Safari
Mascouche , Quebec
So I am...
There is hole in the front to rear cross member as well as up to low... Those wire hole as been use to travel all around the trailer... there's is probably some more mouse nest somewhere...
1998 Safari 25' SS
Old 04-01-2023, 08:18 PM   #9
Waltham , Massachusetts
So what did you do to fill in the space after you took the cabinets out?
thedemodummy is offline   Reply With Quote
removal of front and rear upper cabinet h2oboy Cabinets, Counter Tops & Furnishings 0 09-17-2015 05:10 PM
support for upper storage lockers in 79 7.3 minuet Casa Rodante All Argosy Trailers 3 05-30-2015 03:34 PM
'74 Argosh mh Upper storage bin catches - missing bkahler Argosy Motorhomes 5 10-10-2012 10:44 PM
Bedroom Upper Storage Cabinet Missing UtahChic Cabinets, Counter Tops & Furnishings 1 01-21-2012 06:48 PM
