11-09-2008, 10:15 AM
2002 25' Classic
Oro Valley
What size ball on my 2002 Classic?
Good a.m., My trailer and the manuals are in storage and I have a question--what size hitch ball is required?
As I remember when going to U-Haul last summer for a rental, the ball for the Airstream was not the correct size for the rental trailer.
Kistler & Brenda
2002 Classic 25'
2003 Expedition EB 5.4L, AWD, AdvanceTrac Class IV hitch pkg. Reese dual cam/Prodigy
11-09-2008, 10:17 AM
Retired.
, At Large
Ball size is 2 5/16". Ball on U Haul is generally 2". They (U Haul) tried for a very brief time to go with a 2 1/4" ball size, but that idea was shelved almost as fast as it appeared.
11-09-2008, 10:28 AM
2002 25' Classic
Oro Valley
Thank you, Sir; you saved me some gas on a trip to the storage yard.
I am looking for a trailer to transport my golf car to and from our "summer place". Most, Big Tex, PJs, etc., seem to have 2" balls also.
My next problem will be switching balls (2" and 2 5/16") from towing the Airstream to being able to tow the utility trailer
Kistler
11-09-2008, 01:05 PM
1973 31' Excella 500
Morristown
, Tennessee
I would suggest a seperate hitch to slide into the receiver. They are not very expensive and will save a temendous amount of time compared to changing the ball each time. I did this so I could pull my jon boat to and from the lake - about ten minutes. It is the right height for the boat but wouldn't be if I changed the ball on my heavier Airstream unit. I got mine from the Tractor Supply Company here but would have gone to a standard hitch place in Florida before I moved. Life is too short to be changing balls.
Joe DeFelice
1973 Excella 500
11-09-2008, 04:37 PM
1970 31' Sovereign
Lombard
Joe is right,
I have purchased the 5,000 LB hitches and 1 7/8" and 2" balls at Walmart, if you have one close by. You prob. can pick up a ball and hitch to slide into your receiver for under $25.00 . Their small enough, I keep them behind the bench seat in my truck, just in case I need one.
Best of luck,
Scott
I have a picture of my Airstream in my wallet, and I'm sitting on it...
...If that's not love, I don't know what is!
11-09-2008, 04:38 PM
2002 25' Classic
Oro Valley
Thank you for the suggestion; I will do that.....another receiver bar and ball. I actually have a receiver bar/ball that came with my Jeep. That bar will fit in the Expedition I suppose; the problem (if it is one) will be that the utility trailer will be high in front--low in the rear. I don't know that that matters much???? Just as long as the EZ - GO doesn't unload itself.
I don't even have a wrench that comes near fitting the nut on the ball(s).
Kistler
11-09-2008, 04:42 PM
2002 25' Classic
Oro Valley
I am sold on the plan of a separate receiver bar/2" ball. The Airstream bar/2 5/16" ball is attached to a bar that has quite a drop so the Airstream is level AND my RockTamers are attached to that bar........
Oh well, so I repaint the utility trailer front every season.
Kistler
11-09-2008, 05:03 PM
1970 31' Sovereign
Lombard
They do sell "drop hitches" that would allow you to adjust the ride hieght of your trailer to the tow vehicle. The 5,000 LB class III units are just a few dollars more than the standard hitch. You can also invert them (flip them over 180 degrees) in the receiver if you want the tongue higher...
Best of luck,
Scott
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
ball size
bullydogsmom |
Hitches, Couplers & Balls |
4 |
07-15-2008 05:49 PM |
Hitch ball size
Argosy27 |
1 |
05-23-2006 05:53 PM |
ball size
jlester |
7 |
12-22-2004 07:12 AM |
Ball hitch size
schaumannk |
8 |
12-01-2004 07:31 AM |
tow ball size
iguana |
2 |
10-03-2002 11:39 AM |
