Old 05-30-2010, 06:18 AM   #1
2002 34' Classic
Tecumseh , Ontario
We just bought an '02 Classic 34....
Hello Forum : Well after several years of considerations, the Admiral & I have traded our 97 25ft Safari in on a (very clean) 02 Classic 34.
We're not quite at retirement age yet, & are a bit intimidated by the size of it all...but I figured since we are wanting to full time in the future (during the winters..) it was the right thing to do.
The fact that many of you presently own 34's & (apparently) get along alright with them...was a big part in our decision to take the plunge...& so that leads me to a big question to all of you 34 owners out there...
Owning to her size...because with the tow vehicle it's "a pretty long proposition"...are there any special considerations about owning the 34 that I should be keeping in mind ?
Have you folks that own 34's found that there are any real issues due to her size ?
Many, many thanks in advance to those who kindly respond !!
Cheers, P.
PaulO is offline   Reply With Quote
Old 05-30-2010, 06:30 AM   #2
Road Ruler's Avatar
Images: 38
Sweet! Luv those tri axles!
Old 05-30-2010, 06:44 AM   #3
SARGE/AF's Avatar
1996 34' Limited
1976 31' Sovereign
1983 31' Excella
Greeneville , Tennessee
Cheers, P.
CONGRATS Paul on your purchase, I believe that you will find that after having one for awhile that you will wonder how you ever got along without one. One thing you should be aware of is the temptation to carry more than you should with all the extra space which is going to effect your load ratios and make you over weight or over on front or rear. What type of Tow Vehicle (TV) have you decided on? with this trailer it should be at least a 3/4 ton. One thing that you may also consider is a set of Ride Rites for the TV rear, I just put a set on my 05 Excursion and what a difference in towing and ride.
We bought a 1997 34WB Legend Norman Rockwell edition and tow it with a Ford Excursion. We love the 34, but unfortunately the following is growing smaller and smaller which means that the amount of 34 owners are less and less.
Sarge
SARGE/AF is offline   Reply With Quote
Old 05-30-2010, 07:29 AM   #4
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Backing is a "new" experience once past 28', IMO. Can't go wrong with a sway-eliminating hitch and disc brake upgrade. TV with 4-whl discs and a turbocharged diesel (an '04 305HP/555TQ Cummins, stock, is king for fuel mileage and long life). Twin A/C if you expect to travel in hot weather. Tires all from same lot number preferable. Upgrade to LED signal lighting.
Take your time on setting up weight-distribution, and use certified scales regularly. Same with mirrors. I have used MULTI-VEX inserts on an earlier truck, and am considering going to CIPA replacements on mine to replace factory towing mirrors and add those inserts: no blind spots and no need for convex mirrors afterwards.
I like to use GOOGLE MAP "Street View" to check fuel stations, other, for swing and turn space in trip planning. (My 34' trailer and truck were at 63' total length). BING also has "Birds Eye View" that is helpful.
Old 05-30-2010, 08:08 AM   #5
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Definitely consider the A/C issue. Many of the 34' units are running around with a single 13.5K air conditioner. Woefully inadequate when you hit those 90+ days, camping in full sun.
My dealer used to rave about how well that tri-axle trailer tows. Enjoy!
Jack Canavera
STL Mo.
AIR #56
jcanavera is online now   Reply With Quote
2002 classic
Classic vs Classic limited Flying Gypsies 2006 - 2010 Classic (all lengths) 13 10-15-2011 06:37 PM
2003 Airstream Classic 30 Ft. EXCELLENT!!!! S2003 Airstream Classic 30 Ft. EXCELLENT! eBay Watch Airstreams on eBay 0 09-12-2011 09:50 AM
2011 Classic Limited 30 :: 2011 Airstream Classic Limited Wyndridge2 Airstream Registry Discussions 0 08-19-2011 08:32 AM
Classic -vs- Classic Limited 10Smiles Dollars & Cents 11 06-22-2011 08:33 PM
light bulbs in 2004 classic? art Lights - Interior & Exterior 2 03-03-2011 05:33 PM
