Old 10-18-2010, 02:58 PM   #1
2005 30' Classic
Burlington , Ontario
Unknown water line valve- 2005 Classic
Today, while winterizing our 05 classic 30, I noticed that below the three bypass valves at the hot water tank, there is a line running along the length of the trailer and it has a chromed on off valve - similar to the three on/off bypass valves.
No idea what that would be for unless maybe it is a main water shut off on the incoming city water line - I don't know why you would need one though.
I don't believe it is any sort of low point drain as the trailer has two low point drain valves protruding thru the belly pan underneath.
The valve is in the open position and I have never touched it.
Any ideas as to what it is for? Not that easy to trace the pipe to and fro the valve although I could give it a try.
Thought I'd ask here first!
Brian.
Old 10-18-2010, 03:59 PM   #2
_
just blindly guessing...
it is the shut off for the external water outlet/fixture,
which is located near the btf and main water connection.
this is easy to check.
assuming that IS what it is, drain the line (external fixture)
then turn the INTERIOR valve off.
if routinely using antifreeze
both valves need to be OPEN till pink flows...
cheers
2air'
Old 10-18-2010, 04:46 PM   #3
2005 30' Classic
cheers
2air'
Maybe, but I wouldn't have thought so. There is an external valve to get fresh water located in the outside compartment right next to the fresh water hose connection.
When I winterize the trailer, I crack that external valve open until it runs pink then close it.
I'm a bit concerned about winterizing the actual inlet hose connection. I know that there is a check valve in there and with our last trailer, (SOB) I could depress the valve with a screwdriver and get pink stuff fowing out that way too.
With the AS, there is a filter screen in there and it really doesn't seem to want to come out to allow me to depress the one way valve.
It doesn't seem I could get it out without destroying the screen.
For the last two winters I have ignored it (reluctantly) and just made sure I got good flow of pink stuff out of the adjacent hose bib and all has been well - looks like I'll be doing that again this year!
Brian.
(PS - not sure what is "btf?")
Old 11-06-2010, 08:19 AM   #4
Silver Goose's Avatar
2008 27' Classic FB
Burkburnett , Texas
Mystery valve
Brian.
I have a 2008 Classic FB with what appears to be the same valve configuration, except in my case that valve has always been in the closed position and everything works. To clarify this configuration, there is a cold water line that comes up through the floor, crosses below the water heater and then goes back through the floor. From this line there is a tee that feeds the WH with the normal configuration of 3 valves and a bypass pipe. All of that makes sense. It is beyond the tee where this valve is located. In the 27FB configuration, the WH is located under the bath sink on the curbside. The galley is also located on the curbside. The cutoff valve for the exterior water valve is located under the closet on the streetside near the water pump. This valve remains a mystery to me.
Silver Goose is offline   Reply With Quote
Old 11-06-2010, 08:52 AM   #5
dznf0g's Avatar
Oswego , Illinois
With this valve open, both city water pressure and on board pump will supply water to the outside faucet, since they are plumbed together behind the faucet/city hookup panel in the outside compartment. With the valve closed, the on board pump water is not allowed to go through the valve nor the brass one way valve.
It's really a screwy set up, IMHO.
Old 11-06-2010, 08:54 AM   #6
Ag&Au's Avatar
Port Orchard , Washington
When I asked Airstream customer support a similar question about a check valve in my trailer, they emailed me a copy of the plumbing drawing.
Try asking them what the valve is.
Regards,
Ken
Old 11-06-2010, 09:02 AM   #7
dznf0g's Avatar
Oswego , Illinois
I see No reason for the brass one way valve...unless its in case you're using city water and then travel to freezing temps and forget to close the shutoff and now are using heated on board fresh water. BUT, if you're dumb enough to forget to shut off the silver valve....you're certainly too dumb to remember to open the outside faucet and let any residual water drain out....it'll freeze anyway.
w7, what did AS tell you?......this otta be good!
Old 11-06-2010, 09:21 AM   #8
Ag&Au's Avatar
Actually they didn't know either.
However when they sent the diagram and I figured out that there was a labeling mistake on it, I was able to see what the check valve does.
It is a check valve in parallel with the exterior faucet shut off valve.
The exterior faucet is connected to the same pipe as the freshwater inlet right next to it. Therefore if the check valve where not present, there would be no fresh water available from the inlet fitting if the exterior faucet shut off valve were closed. The check valve allows outside incoming water to bypass the valve, while keeping water from the trailer's tank from reaching the exterior faucet when the shutoff valve is closed.
Regards,
Ken
Old 11-06-2010, 09:49 AM   #9
dznf0g's Avatar
Oswego , Illinois
W7, that's correct, but I still think it's screwy....see post #7.
Old 11-06-2010, 09:50 AM   #10
dznf0g's Avatar
Oswego , Illinois
Those two valves are from the Department of Redundancy Department.
Old 11-06-2010, 10:26 AM   #11
Ag&Au's Avatar
Sorry, I didn't read all of your post 7 the first time.
For my part I am glad it is there.
I leave my shut off valve closed all the time. I have yet to find a need for the outside faucet.
If I am in a RV park with water connection, and it is going to freeze during the night, I simply disconnect the water, open the outside faucet to drain that part of the plumbing, and use the FW tank for the rest of the night. If that check valve were not there I would have to be messing around under the bathroom vanity to turn the shut off valve off and on.
To each his own.
Ken
Old 11-06-2010, 10:51 AM   #12
dznf0g's Avatar
Oswego , Illinois
I do use my outside faucet. I got one of those short garden hose pieces, about 6' long and a "trigger" style nozzle. I bungee it to the BR awning strut and I have an outdoor rinse of station. Rolls up and stores in the faucet compartment.
Old 11-06-2010, 11:43 AM   #13
2016 30' Classic
Sammamish , Washington
There should be 2 shut off valves in the 27fb: one for the toilet (to allow servicing) and one for the outside faucet (to prevent freezing when using the trailer in cold weather). In our 27fb, one of the valves is by the water heater under the lavetory sink and the other valve is under the acess panel in the closet.
PJohnson is offline   Reply With Quote
Old 11-06-2010, 01:46 PM   #14
_
Originally Posted by w7ts View Post
...I leave my shut off valve closed all the time. I have yet to find a need for the outside faucet...
exactly.
and that short section of pipe to the outside faucet CAN freeze.
i have used the outside faucet only 4-5 times.
each use was after returning to covered storage from a long trip.
first time the trailer was filthy and covered with salt.
so the fresh tank was used to soap WASH/rinse, detail the stream in the storage lot.
this used up the entire fresh tank (~45 gallons) which need to be drained anyway.
all the other times the outside faucet was used to QUICKLY drain the fresh tank rather than use the nylon drain valve.
the pump/faucet takes about 15-30 minutes to complete what otherwise may take hours.
still it makes good sense to keep that line in the OFF position during the cold months.
cheers
2air'
2005 classic
