Old 06-11-2004, 12:52 PM   #1
gklott's Avatar
2004 30' Classic
Johnson City , Texas
Images: 86
Underside damage truck tire tread - 2004 Classic
In April, while driving in heavy city traffic, we ran over a piece of tire tread lost by a big truck. Couldn't avoid it. Was doing 55 or so. Hit it with the truck and the trailer.
That appears to be the source of several things.
- broken off fresh water tank pitcock
- bent front curb stabalizer shaft
It may be the cause of the lower door hinge pin rising out while driving. After driving to San Diego 2 weeks ago, I noticed the beginning of a front curb tire wear pattern similar to what yoiu might see on an out-of-balance tire. Am having the shocks and tire looked at carefully for damage. The other tires look fine.
Wonder if that could have also been the cause of the steps damage we noticed?
Any other suggestions on what to look for?
73/gus
Gus - KR4K : Mary - K5MCL
2004 30ft. Classic
2017 Infiniti QX80 Limited
ProPride 3P/Prodigy P3
gklott is offline   Reply With Quote
Old 06-11-2004, 08:15 PM   #2
59toaster's Avatar
1959 22' Caravanner
Atlanta , Georgia
Images: 22
OY!
Road gators will do a number on stuff. Since you have so many probale oall on the same side It had to be the tire. Check the bell pan and make sure it's still riveted on good. On the older coaches if the rivets in the center fail the pan will move a lot as air goes under it and the ends of the out riggers will wear through the belly. It looks awful.
Sounds like you have the rest covered.
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
59toaster is offline   Reply With Quote
2004 classic
