Old 11-15-2005, 12:52 PM   #1
Tire pressure - 2005 Classic
Anyone have any recommendations on tire pressure for a 99 Ford F250 turbo diesel pulling a 30' classic?
Scott Hopkins
Scott Hopkin is offline   Reply With Quote
Old 11-15-2005, 01:37 PM   #2
Cartoon Character
Porky Pig's Avatar
2004 34' Classic
On The Road , U.S.A.
Scott,
You will need to know your tire size and how much weight is on your front and rear axles.
Then look it up here: ...http://www.goodyear.com/truck/pdf/LoadInflLTMetric.pdf
Porky
TrailerGypsies.com
WBCCI #3405 Escapees #80360
I live the life I love and I love the life I live.
-- Willie Dixon
Porky Pig is offline   Reply With Quote
Old 11-15-2005, 04:49 PM   #3
Steve Heywood's Avatar
1997 30' Excella
Waddell , Arizona
Images: 13
Scott Hopkins
Scott,
My rig is very similar to your (see SIG). My rig weighs 15460 lbs. loaded for a typical trip, 4300 front axle, 3940 rear axle, and 7320 on the trailer tandems. According to the Goodyear inflation charts I carry, my tires (265/70-17 truck, 225/75-15 trailer) need just 40 PSI to support this weight. I was taught to run a minimum of 10 PSI above the minimum so I routinely run 50 PSI front and rear on the truck. I consider 50 PSI the absolute minimum for the trailer and usually run 55-60.
Steve Heywood
Waddell, AZ
1999 19' Bambi (SOLD)
1997 30' Excella (SOLD)
Steve Heywood is offline   Reply With Quote
Old 11-15-2005, 04:56 PM   #4
StingrayL82's Avatar
San Angelo , Texas
Images: 37
Scott,
Check your door....there should be a sticker, which tells you what the inflation pressures should be, both unloaded and loaded.
Frederic
Frederic
1971 Sovereign International - SOLD
2004 F-350 King Ranch
AIR # 8239
EX-WBCCI # 8371
StingrayL82 is offline   Reply With Quote
2005 classic
