Old 01-31-2012, 12:08 PM   #43
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Originally Posted by Bluto View Post
Don't have a leak. I have the fiber glass bumper without a cover door. Just preventive maintence of drilling a couple of holes to stop puddling of water on top of bumper and under beltline. I'm not traveling now so it's a good time to look into doing this kind of stuff and looking at caulking in various places on the trailer.
Bluto,
7/32" about 3/8" back on both seams, will drain right to the ground on our Classic. Poke a stick thru one in awhile to keep it clear.
Going on 7mos now and the trunk and both rear side storage compartment floors are still dry.
PFC
but Iím the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 01-31-2012, 12:15 PM   #44
dznf0g's Avatar
Oswego , Illinois
Bob, your drain points and low spots (re. the earlier posts where I asked about the 1/2" gap) are really interesting. Those areas are high spots on mine. Or looking at the inverse...my low spot and pooling is in the center of the middle fiberglass section. Seems to be another in the never ending build variations.
-Rich-
Old 01-31-2012, 12:50 PM   #45
Not vary consistant in their inconstantancies are they?
PFC
RLC
Old 01-31-2012, 01:37 PM   #46
2010 27' FB Classic
N/A , Texas
Thanks Bob!
Old 01-31-2012, 07:00 PM   #47
idmtman's Avatar
Worley , Idaho
I had a similar leak. Started by removing the trim and recaulking. Still leaked. Caulked the top of the trim, still leaked. Caulked the marker lights and rear light housing, still leaked. Finally recaulked the rear window eyebrow; no leak. Start high was suggested to me and that seems to be good advice.
Idmtman
2006 Safari 28' SE (Sylvia)
75th Anniversary Edition
2010 Toyota Tundra 4x4
TAC: ID-1
idmtman is offline   Reply With Quote
Old 01-31-2012, 07:03 PM   #48
dznf0g's Avatar
Oswego , Illinois
Another often overlooked entry point is the "pocket" style license plate mount. Mine had no sealer at all around it. I used closed cell foam tape so bulb maintenance can be accomplished easily.
-Rich-
2004 classic
