Hopefully this will save someone else some headache. The power wire coming from the pump is orange. Removing the monitor shows 3 orange wires coming up from the wall, spliced in yellow, green, and purple wires. The manual shows the purple wire as the power, which was plugged into the left (on) green wire plugged into the right (off) and yellow was unplugged. Did a continuity test and found that the color wires were incorrectly wired onto orange. The yellow wire turned out to be the power wire. Did continuity test on other wires and confirmed. Plugged into the empty spot on switch, and voila. Pump works perfectly.
