Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Classic > 2001 - 2005 Classic
Old 08-29-2018, 04:07 AM   #1
Cudjoe Key , Florida
Micro Pulse monitor photo
Can someone post a photo of how all the wiring is connected to the micropulse monitor? My water pump won’t work and we think it’s not getting power. I want to verify everything is connected in the right place in the back of the monitor station. A photo of the front would help too so I can ensure we have the same one. Thanks
Seth
Super Fam is offline   Reply With Quote
Old 09-02-2018, 04:57 AM   #2
Hopefully this will save someone else some headache. The power wire coming from the pump is orange. Removing the monitor shows 3 orange wires coming up from the wall, spliced in yellow, green, and purple wires. The manual shows the purple wire as the power, which was plugged into the left (on) green wire plugged into the right (off) and yellow was unplugged. Did a continuity test and found that the color wires were incorrectly wired onto orange. The yellow wire turned out to be the power wire. Did continuity test on other wires and confirmed. Plugged into the empty spot on switch, and voila. Pump works perfectly.
Micro Pulse Tank monitor calibration Silvertwinkie Plumbing - Systems & Fixtures 101 07-16-2023 07:34 PM
Micro-Pulse Systems Monitor Bites the Dust Wayne&Sam General Repair Forum 22 08-25-2011 08:04 AM
Micro Pulse tank monitor issue wildwoodrver Electrical - Systems, Generators, Batteries & Solar 12 10-28-2010 06:20 PM
Micro Pulse Monitor reads red when unhooked foqus Batteries, Univolts, Converters & Inverters 11 11-03-2009 09:34 PM
Micro-Pulse tank monitor blues dlb435 Waste Systems, Tanks & Totes 11 07-14-2009 01:53 PM
