Old 01-21-2004, 05:48 PM   #1
flyfisher's Avatar
2004 30' Classic
Field and Stream , PA & MT
Insulation used in Classic Limited series - 2004?
The summer before last when my wife and I toured the Airstream factory we saw they were using a different type of insulation under the floor in the Limited series only, and the tour guide said (as I recall) that it was rather expensive, and a more effective insulation than that used in other models. I think he said the insulation originated in the aerospace industry.
Does anyone have more information about this insulation. Are they still using it in 2004 models? And, if it is more effective, I wonder whether a person could special order an entire trailer insulated with it?
John
Flyfisher
flyfisher is offline   Reply With Quote
Old 01-21-2004, 10:16 PM   #2
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
That insulation is used in the walls and ceiling also. It is a higher R value. Our tour guide said it was used in the Limited trailers only, but I bet they would upgrade for a price.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 01-21-2004, 11:23 PM   #3
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
I believe they are still using it in the Classic line. I also agree with Jack that they might install it into the Safari and CCD lines at additional cost.
Old 01-22-2004, 03:33 AM   #4
lynn's Avatar
I believe that the foil bubble type insulation is only used under the floor and only in the Slide Out Trailers. They were not able to use the fiberglass insulation under the floor due the slideout mechanism.
lynn is offline   Reply With Quote
Old 01-22-2004, 05:56 AM   #5
flyfisher's Avatar
2004 30' Classic
Thank you for your replies. I like the idea of the extra R value since we routinely camp in temperatures exceeding 100 degrees, as well as below freezing.
John
Flyfisher
Old 01-22-2004, 07:27 AM   #6
jcanavera's Avatar
Fenton , Missouri
Images: 143
Eric, the Classics have the same insulation as your Safari does. Its just the units with the "Limited" moniker that get the better stuff.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 01-22-2004, 07:31 AM   #7
Aluminut
2004 25' Safari
. , Illinois
I think you're right...as I think about it that week I visited the factory, there were mostly all Classic LTDs on the line.....
Old 01-22-2004, 05:29 PM   #8
lynn's Avatar
The airstream trailers are built using fiberglass insulation in the walls (shell). All trailer models.The foil insulation is only used in the floors on slideout units.
Old 01-22-2004, 08:02 PM   #9
jcanavera's Avatar
Fenton , Missouri
Images: 143
Lynn,
Do you know if A/S allows the insulation that they put into the Limited's to be ordered as an option for their other trailers?
Jack
Jack Canavera
STL Mo.
AIR #56
Old 01-22-2004, 08:28 PM   #10
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
When I had my Scamp with an uninsulated floor, after spending a summer week in Las Vagas, I insulated the floor with the foil-bubble insulation. It worked great. Scamp insulates the upper part of the trailer with the same material. It is glued to the fiberglass shell with contact cement and a fabric, very much like in current Airstreams, is glued to the foil. The Scamp was a very snug trailer once I did the floor.
The foil-bubble insulation conforms nicely to curved surfaces. If I were working with a vintage unit and had inner panels off, I would certainly use the material in place of the fiberglass bats.
In my Scamp, I also insulated the walls of the refrigerator cabinet to keep heat out of the interior. Prior to that, the pantry would get terribly hot inside.
John W. Irwin
WBCCI #9632
Old 04-24-2004, 10:20 PM   #11
1983 34' Limited
Las Vegas , Nevada
Send a message via MSN to dmadam
When did they start using the better insulation in the Limited. Mine is an '83. Is that to far back?
David
Retirement happens when you get over the illusion of usefullness.
dmadam is offline   Reply With Quote
Old 04-25-2004, 06:30 AM   #12
lynn's Avatar
Foil insulation
I would not say the foil is any better insulation wise than fiberglass batt insulation.
It offers some features fiberglass cannot such as: it is thinner and it is not as "itchy" to work with. It is also more expensive.
I do not believe it is an option but it may be something they would do as a "special order", you would need to contact factory. They started using this insulation on the Limited slideout trailers in 1999.
Old 04-25-2004, 08:31 AM   #13
BobbyW's Avatar
1965 20' Globetrotter
Houston , Texas
Is this it?....
BobbyW
AIR# 123
-"You want to make it two inches - or, if you're working in centimeters, make sure it's enough centimeters for two inches."-Red Green
BobbyW is offline   Reply With Quote
Old 04-25-2004, 12:28 PM   #14
jcanavera's Avatar
Fenton , Missouri
Images: 143
According to the tour guide doing the Airstream factory tour the insulation used on the Limiteds does have a higher R value.
Jack
Jack Canavera
STL Mo.
AIR #56
2004 classic
