Old 05-30-2005, 01:00 PM   #1
Pappy's Avatar
2006 25' Classic
Floyds Knobs , Indiana
Convertor question - 2005 Classic
We have ordered a new classic 25 to be completed hopefully by June 29th.
Can anyone tell me what name brand convertor they are using now and the specs?
I need to know if it has a multistage charging system built in or is it just stuck in one voltage range? If so what is the current output and voltage the unit is set at?
Does the fresh water system have a fill opening or is it a pressure fill ?
Thanks Pappy
Pappy is offline   Reply With Quote
Old 05-30-2005, 08:55 PM   #2
Tinsel Loaf's Avatar
Call Airstream Jackson Center tomorrow. They will be happy to answer all your questions.
Tinsel Loaf is offline   Reply With Quote
Old 05-30-2005, 09:42 PM   #3
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
Does the fresh water systemhave a fill opening or is it a pressure fill ?
Thanks Pappy
It is an Intellepower 7400 series 55 amp converter. You can look up the specs on the web.
The fresh water tank has a lockable fill opening on the curb side, just outside the galley sink area. The city water (pressure) inlet is on the street side, about under the credenza.
John W. Irwin
WBCCI #9632
2005 classic
