03-20-2018, 11:26 AM
2005 30' Classic S/O
East Bethel
Can't get key into upper lock
We shut the door and locked both locks with their respective keys. Now we can't get the key into the upper lock. We are locked out of our trailer. Any suggeztions?
03-20-2018, 01:09 PM
Tampa
One step at a time.
Does the key go in but not turn?
I'd try some graphite lock lube.
Or is the slot blocked or rusted?
I'd try some light machine oil (remember 3-in-one?)
Are you in Minnesota now and frozen?
03-20-2018, 02:56 PM
1999 30' Excella 1000
small town
, Maryland
Welcome to the forum shazz. If you have a queen bed, open rear storage compartment. Slide in on your back, and push up on the bed. Have a extra set of keys made for the tow vehicle. Hope this helps
03-20-2018, 03:01 PM
2007 22' International CCD
Corona
Sounds like ice in the lock.
Warm the key gently with a lighter or match, see if it will go in. May take a couple tries to melt the ice.
03-21-2018, 09:16 AM
1978 Argosy Minuet 6.7 Metre
1971 27' Overlander
1973 31' Sovereign
Griffin
, Georgia
Spray the lock and key with penetrating oil.
Old realtor trick
03-21-2018, 09:18 AM
2008 25' Safari FB SE
El Cajon
The upper lock is very sensitive to how far the key penetrates (depth inserted). I had a locksmith make a duplicate key that would not unlock the lock. She remade key several time before realizing that the blanks head was slightly larger than the original. Even though it seemed to be fully inserted it wasn’t.
03-21-2018, 10:45 AM
Ottawa
, Ontario
After a similar problem following an ice storm I poured windshield washer fluid over the locks and the key and all was fine after a few seconds.
03-21-2018, 01:38 PM
Canyon Country
Silicon or Teflon Spray. Works, 99% of the time
03-21-2018, 05:23 PM
2017 22' Sport
Gatineau
, Quebec
All of the above suggestions. Also, try pushing strongly on the door. Sometimes it realignes the variuous parts of the lock.
COURANT D'AIR
03-22-2018, 08:17 PM
bhooves
2013 27' Flying Cloud
Livingston
Apparently this is a common problem. We had it. Towed trailer 200 miles or so from Yuma AZ to Lazydays RV Airstream dealer, They had to drill about a half inch hole in the upper lock panel, remove the entire mechanism an install a new one. It appears that this lock is used on many other brands of RVs and this is a common problem. Grin, bear it and get to a dealer
Oh the irony of parking our Airstream in a motel parking lot the night before the dealer would be open....
03-23-2018, 05:48 PM
2017 30' International
Lincolnwood
keys
If you are using keys made at a store, make sure you are using the correct key.
Double check that you are not using look-a-likes. I've done that. Took me a while to figure it out.
