Old 02-19-2016, 08:38 PM   #1
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
Box behind propane tanks 2002 Classic 30 S/O
What is the purpose of the box behind the propane tanks? It has a lid, but is not water tight. Mine has apparently trapped water between it and the frame cross member it is welded to the bottom of. The weld is rusting as is the box and the corner of the frame cross member. I can't decide whether to try to fix it or cut it off.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 02-19-2016, 08:43 PM   #2
1986 31' Sovereign
Miami , Florida
On many models it is a battery box. On mine, the batteries are installed elsewhere somI use it to store my Lego blocks.
Mike
Old (usually dirty) Nissan Titan
Old (enhanced with "male pattern baldness") Sovereign
Young, lovely bride
Goofy dog, dismissive cat
Old 02-19-2016, 08:58 PM   #3
1998 30' Excella 1000
Livingston , Texas
Mine sounds like yours. I use it to store an extra 10' sewer slinky (for the times that my 20' is too short) and the fitting that goes into the dump (but won't fit into the under-rig pvc storage pipe).
I enlarged the internal drain holes in the bottom of the box and had to steel wool/wire brush it and prime and paint it a few years ago. The seam/joint between the box and the cross member is right below the rub-rail. I caulked it.
Siegmann is offline   Reply With Quote
Old 02-19-2016, 09:13 PM   #4
Mike
It's not deep enough for batteries. I think it is storage, but since the lid is not sealed, I'd only put plastic stuff in it. Seigmann's idea sounds good.
My round sewer hose storage pipe was broken when I got the trailer, and the ones on my Safari 25 wouldn't fit the fittings either. I saw something on a MoHo site where a guy had made a tube out of a 4" PVC fence post cover. I bought one, but it wasn't big enough either. I made two storage tubes, one for sewer hose and the other for flagpoles out of 5" PVC fence post and caps. I hinged the caps on one end and used screws on the other in case I needed to take the cap off. I'm going to make another pair for my 30.
Al
S/OS #004
Old 02-20-2016, 06:38 AM   #5
87MH's Avatar
1978 31' Sovereign
Images: 292
Hydraulic Brake
You will find that this box is utilized by the factory to mount the hydraulic brake power head and reservoir.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Old 02-20-2016, 10:24 AM   #6
Rivet Puller
SeeMore's Avatar
2004 28' Safari S/O
Marietta , Georgia
Battery Box
On my unit it is the battery box. I modified the lid mounting so it could hold 2 golf cart size, 6v batteries.
Name:	Battery Compartment.jpg
"Good judgement comes from experience. Experience comes from bad judgment."
Sirs Gawain & Galahad
Air #48582, S/SO #003, WBCCI #4584
SeeMore is offline   Reply With Quote
Old 02-20-2016, 10:39 AM   #7
pappy19's Avatar
Garden Valley , Idaho
I use mine to hold some of the hitch parts when I unhook. My batteries are inside the main frame with 2 outside doors.
2008 F-250 4X4 Lariat V-10
2007 Kubota 900 RTV
1996 Ford Bronco
2007 Lincoln LT
pappy19 is offline   Reply With Quote
Old 02-20-2016, 10:41 AM   #8
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
I have 2 trailers with the box. Both came with the aluminum cone that is the base for the jack and chocks for the wheels in the little box. So I use mine for that and have added a wrench and a extended lever for the lifts.
Old 02-20-2016, 10:47 AM   #9
That sounds like the best use so far. I have been putting the jack foot in the truck and the chocks in a rear compartment. I need to figure out how to stop the water entrapment between the box and the frame cross member and fix the rust. I'm thinking I'll grind out the rusted weld and then fill the area with Sikaflex or something.
Al
S/OS #004
Old 02-20-2016, 11:40 AM   #10
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
Mine holds my sewer fittings, elbows, foam collar, and the like. I carry spare hose ends after I dropped a hose on concrete and broke an ear off the connector. If you have a Thetford outlet on your trailer, best either carry an extra end or a Thetford to Valterra adapter since most places do not carry Thetford hose parts.
John W. Irwin
WBCCI #9632
Old 02-20-2016, 12:56 PM   #11
1996 25' Excella
Tillsonburg , Ontario
Mine holds the block for the jack and the jack foot. I used to keep a rag in there for wiping my hands of grease, but as noted it is a wet space. While traveling I also keep the Hensley cam wrench in it but not while in storage as it is not secure.
JCW
JCWDCW is offline   Reply With Quote
Old 02-20-2016, 03:07 PM   #12
NOAZRK
NOAZRK2690's Avatar
2004 34' Classic S/O
Kutztown , Pennsylvania
Cool
Just get someone to tack weld whatever is wrong with it. Try sanding & cleaning the interior then brush on two coats of oil base aluminum paint by Rustoleum. Aluminum paint is also good for the rear bumper utility drawer. I use the box to store miscellaneous hitch parts, bearing grease, whatever. Not sure why anyone would want to cut the thing off.
NOAZRK2690 is offline   Reply With Quote
Old 02-20-2016, 03:40 PM   #13
sandlapper's Avatar
1993 34' Excella
York , South Carolina
I read once, somewhere, where it referred to as the flag box by Airstream. No matter what, it was intended for storage of things that could get wet.
On the late models it became the battery box as others have noted.
Make sense to store things in it that are used at the front of the trailer.
John
WBCCI #3892
Region 3 , 1st VP
Go often to the house of a friend, for weeds choke the unused path........Emerson
Never pick a fight with an old man. If he is too old to fight he will just kill you........a wise old man.
sandlapper is offline   Reply With Quote
Old 02-20-2016, 05:50 PM   #14
My thought about cutting it off was I wasn't sure what it was used for and it appears to be trapping water between itself and the frame which is causing rust on the frame cross member.
I'll try some maintenance procedures first.
John, I saw in the Standard Equipment List that the trailer was supposed to have a flag storage box. I'm not sure I'd want to store flags in there, but I haven't found one anywhere else. It seems like a great place for chocks, grease, and the jack foot, however.
Al
S/OS #004
I have 3 boxes of assorted parts from my airstream 59 Tradewind, I would like to sell by the box for 300.00 per box or best offer per box betsy Airstream Classifieds 0 09-19-2014 11:01 AM
Adding a second battery in the stock location behind the propane tanks.... drboyd Batteries, Univolts, Converters & Inverters 4 06-12-2014 04:23 PM
New cover for box behind LP bottles... Dwight Brakes & Brake Controllers 0 12-27-2010 09:57 AM
locks for battery box and propane box Chilao Doors & Locks 11 11-02-2004 06:56 PM
