Old 05-02-2005, 10:45 AM   #1
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
Bathroom storage for any recent 25' - 2003 Classic
This should apply to all recent years of 25' center bath trailers.
I noticed that there was a wide spacer between the forward bathroom wall and the refrigerator cabinet. I knew that this space is totally empty except for the vent pipe for the black tank; therefore, I had the opportunity to add some welcome storage to the bathroom.
One photo shows the wall before I started. The mirror was added (with my approval) by the dealer to cover a sealer stain on the wall, rather than replacing the wall. The area above the toip towel rack is where I put the new cabinet. I could put a second cabinet between the towel racks, or even remove the top rack and put in a really big cabinet.
I drilled a couple of holes to locate the pipe and then cut a square opening with a sabre saw. I used a rotary cutter over the pipe set to the thickness of the wall so as not to cut into the pipe.
A second photo shows the new cabinet with cover closed. The floral ornamentation is routed into the oak and then hand painted. Externally, the cabinet is all red oak finished with Golden Oak stain. The interior of the cabinet is 1/2" poplar which is a lot lighter and less costly than oak.
A third photo shows the cabinet open, displaying the slot for the pipe. The sides of the slot are thin aluminum and the cabinet back is black laminate left over from a previous project. When the cabinet is in place, fuzzy hull liner will be glued around the pipe and aluminum sides for a finished look.
The new cabinet is a lot deeper than the OEM cabinet and about doubles the shelf space available.
I still have some staining and varnishing to do. I'll post a photo with the cabinet in place after installation..
ID:	11894   Click image for larger version
John W. Irwin
WBCCI #9632
Old 05-02-2005, 10:57 AM   #2
wheel interested's Avatar
2007 23' International CCD
Lapeer , Michigan
Great idea and I like the hand painted etching on the cabinet door. I have been wondering what to do with the blank space, your project is as pretty as it is useful. There's no such thing as too much storage!
Caroljb
photography
wheel interested is offline   Reply With Quote
Old 05-05-2005, 10:04 PM   #3
Pahaska's Avatar
Hays County , Texas
All installed
Here are photos of the cabinet installed in the trailer.
1. The hole cut and ready for the new cabinet.
2. The cabinet in place and closed
3. The cabinet in place and open. The vent pipe is covered by fuzzy hull liner I had left over from a prior SOB trailer (Scamp) applied with 3M spray adhesive.
The wall below the cabinet is still stained badly. I have to either have the former mirror shortened or else figure a different way to cover the area inside the towel racks.
ID:	11996   Click image for larger version
John W. Irwin
WBCCI #9632
Old 05-06-2005, 09:30 AM   #4
myboyburt's Avatar
1993 25' Excella
Beautiful , New Hampshire
Images: 12
Beautiful!
Lucky for my husband our older (1993) 25' Excella already has a cabinet on the wall behind the toliet. Saves him from having to recreate your cabinet for our side bath unit.
I love that you are sharing the improvements you've made to your trailer. Your book rack (under the fold out table) and flashlight holder are on Leon's "honey do" list for ours.
Michelle & Leon
New England Unit
myboyburt is offline   Reply With Quote
2003 classic
