Old 05-24-2005, 01:07 PM   #1
Rookie Airstreamer
ABS drainage system - 2005 Classic
I just bought a new 25ft CCD airstream trailer. What is the best soap to use to wash the trailer with? Can anyone help me out here?
Thanks Jake
RoadToad is offline   Reply With Quote
Old 05-24-2005, 01:18 PM   #2
Detergents
AS manual says not to use any dish washing detergent that has petrolim based products in them and to make sure that anything that goes in the holding tank is safe to use in ABS drainage systems. Dawn has petroleum based products in it and it has not been tested in ABS systems. What do you use to wash dishes?
scotthopkins@tampabay.rr.com
Scott Hopkin is offline   Reply With Quote
Old 05-24-2005, 01:24 PM   #3
cosmotini's Avatar
1963 24' Tradewind
Highland , Illinois
Images: 83
I believe that the Armor All car wash soap has been determined safe to use.
Dennis
cosmotini is offline   Reply With Quote
Old 05-24-2005, 02:00 PM   #4
Camping world has a RV wash & wax that is pretty good,not to much $$$ either.
cynthia is offline   Reply With Quote
Old 05-24-2005, 03:44 PM   #5
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Armor All Car Wash works well. Also follow-up with Walbernize Super Seal and it will gleam!
Old 05-24-2005, 04:25 PM   #6
ABS drainage system
Have an 05 classic 30. Manual says not to use dish washing detergent that contain petroeum products and is not approved in ABS drainage systems. Dawn has petroleum products and has not been tested with ABS drainage systems. What do you use?
Old 05-24-2005, 04:42 PM   #7
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Interesting. I really haven't noticed that in my manual. I'll have to take a look. Personally I think most dish detergents are safe in your Classic. I've used most brands over the last 25 years in all kinds of trailers with plastic drain pipes. Never have had one fail yet. As a matter of fact I don't remember any detergent with labling stating that its safe for ABS systems. If you are really concerned you may need to do some label reading. Its pretty hard to find any out there that doesn't show petroleum in the ingredients.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 05-24-2005, 07:11 PM   #8
Chaplain Kent's Avatar
1994 30' Excella
Milwaukee , Wisconsin
I was wondering if any of these new no dry products would work. I do not mind washing my Chummy but the drying takes a long long time.
Chaplain Kent
2015 Coachman Freedom Express 19RBS, Chummy IV- Ford Excursion- 7.3 Turbo-diesel
Chaplain Kent is offline   Reply With Quote
Old 05-24-2005, 08:42 PM   #9
Tinsel Loaf's Avatar
My auto detailer told me not to use soap. Just use water and go after only the spots and streaks with a mild cleaning agent ( I think they used armor All ) wiping it clean with just water. If you could get a reverse osmosis unit you won't have spots.
Tinsel Loaf is offline   Reply With Quote
Old 05-24-2005, 08:48 PM   #10
1994 30' Excella
Mississauga , Ontario
I think the only reason not to introduce petroleum products into the drain is the effect it probably has on the seals in the dump valves etc. All houses use abs piping and all dishwashing detergents seem to have no bad effects on the piping. Not even those harsh dishwasher detergents.
Al
Old 05-24-2005, 08:49 PM   #11
1994 30' Excella
Also don't put petroleum products in your drains cause it is just bad practice. Especially for your septics.
Al
Old 05-24-2005, 09:12 PM   #12
Janets Husband's Avatar
1977 Argosy Minuet 6.0 Metre
1964 26' Overlander
1977 25' Tradewind
Eastern , Washington
Who'd a Thunk it?
Never even crossed my mind, but it's a good thought.
I guess that is something I'll have to look at.
Thanks for the tip.
Peace
Gary
Janets Husband is offline   Reply With Quote
Old 05-27-2005, 08:34 AM   #13
Detergent
AS manual says not to use detergents that contain petroleum products and to make sure they are safe for ABS drainage systems. I have checked all the normal brands and none of them say anything about ABS drainage systems. Dawn uses petroleum products and they have never tested it in ABS dfrainage systems. Any suggestions on what to use?
Old 05-31-2005, 04:19 AM   #14
What kind of detergent do you use? I have looked at everything in the grocery store and find nothing that says it is safe to use with ABS drainage systems.
2005 classic
