Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Classic > 2001 - 2005 Classic
Old 11-09-2002, 05:25 PM   #1
Kistler's Avatar
2002 25' Classic
Oro Valley , Arizona
2002 Classic 25' suspension?
I/We are new to TTring especially by Airstream
Can you explain the suspension system? Is/has it changed from prior years?
Does it involve torsion bars? Are those shock absorbers the best? Should I buy Bilsteins for my Airstream?
Holiday Rambler once had a different type of suspension...have forgotten what they called it....is this similar to Airstream?
I looked underneath and I don't seem to have axles...
Kistler
Kistler is offline   Reply With Quote
Old 11-09-2002, 05:31 PM   #2
overlander
Guest
Posts: n/a
yes!
how is the suspension set up on the new models..........is it a new design . is it made by a different manufactur or the same........is it possable to put the new (if there is a new) style suspension on older models?
Old 11-09-2002, 05:35 PM   #3
Kistler's Avatar
2002 25' Classic
Not exactly an engineer here What I see is tandem wheels and each side has two shocks. I cannot see what is across from the front set of wheels (holding tanks in the way) but the rear set has a square tublar (sp?) think it is hollow, bar across between the frame beams.
Kistler
Old 11-10-2002, 09:02 AM   #4
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Hop over to www.inlandrv.com/tours/axle-plant Andy has lots of information regarding Henschen axle and a factory tour of the folks who make it. The only changes recently are the fact that the new Internationals are showing up without shock absorbers. Other than that the current suspension has been around for years. Airstream owned Henschen at one time but spun it off in recent years.
I know that along with Airstream, Holiday Rambler and Hi-Lo were other manufactures who used this axle.
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
Old 11-10-2002, 12:57 PM   #5
Kistler's Avatar
2002 25' Classic
Thank you for the website!
Thank you for that website, Jack. Good information to have; I like to know how "things" are put together.
Kistler
Old 11-10-2002, 02:00 PM   #6
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
I have ordered new axles for my Airstream. I will be traveling to Jackson Center to pick them up myself, in about 2 weeks. If I can I will take some pictures, if they allow it. I am also planning on visiting the factory, while I am in town.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 11-10-2002, 02:11 PM   #7
Kistler's Avatar
2002 25' Classic
We were just in OH (Chagrin, Brecksville, stayed at Jellystone in Mantua) in September. I wish I would have known then that we were getting an Airstream--would have gone down to Jackson Center and did a tour (or two).
Kistler
Old 11-12-2002, 01:01 PM   #8
jcanavera's Avatar
Fenton , Missouri
Images: 143
Kistler
Well worth your time. You gain a new appreciation for your trailer. I was quite surprised at the level of access they gave us. Not only were we able to talk to the workers, but we were allowed to climb in the trailers at various points in the construction process. I took my video cam and camera and walked away with lots of pictures.
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
2002 classic
Classic 25 Bathroom Accomodations DreamStream Our Community 12 02-27-2004 09:23 PM
Safari vs. Classic (25') RivetED Our Community 13 01-21-2004 11:48 PM
CD player option? in 2002 Classic w/Sony Kistler 2001 - 2005 Classic 12 12-13-2003 12:45 PM
2003 25' Classic Pahaska 2001 - 2005 Classic 56 11-10-2003 09:23 AM
Questions about new 2002 Classic Kistler 2001 - 2005 Classic 6 10-31-2002 10:19 PM
