1971 31' Sovereign
1973 29' Ambassador
1978 31' Sovereign
Palm Desert
Broken propane valve to water heater
Time to take care of another problem. I noticed the lever to turn off the LP to the water heater has broken off under the trailer. I bought 2 ovens to replace my inop oven. I'm wondering, if I can get the correct fittings, can I use a shut off valve from the oven? It looks a little different on the outlet end. Thanks.
If you get the correct fittings you can use the other gas valves.
__________________ "If it can't be reduced, reused, repaired, rebuilt, refurbished, refinished, resold, recycled or composted then it should be restricted, redesigned or removed from production."
