Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Classic > 2003 Classic
Prev Previous Post   Next Post Next
Old 05-18-2005, 05:42 PM   #1
Pahaska's Avatar
Profile:  2005 28' Classic
Austin (Hays County) , Texas
Images: 13
New battery switch
I have to replace both my batteries, so I'm going to upgrade the battery disconnet switch at the same time to a marine switch that will allow me to select either single battery, both batteries, or off. The switch was about $20 in the marine aisle at Academy. The RV dealer had the same switch for about $35!.
That will allow me to better judge my battery use when dry camping and also better charge up the batteries. A single battery on line will charge more efficiently than two in parallel.
I had to remove the legs from the marine switch with a hacksaw to fit it into the space behind the sliding sofa front. I simply revolved the red plastic switch body against a sharpie pen on a wood block to get an even line all around and then applied the hacksaw. A little trimming with the belt sander and the switch is ready to install.
I'm tired of having to slide out the sofa front to turn the batteries off and on, so I may put a trimmed opening in the sofa front to access the switch.
John W. Irwin
2005 Classic 28 "Sabre-Dog III"
2007 Silverado 2500HD Duramax/Allison LTZ
WBCCI Region 9 Webmaster, #9632
Battery Location uwe 1970-79 Tradewind 22 09-04-2003 08:44 PM
igniton switch and the mystery of the dead battery Curtis-79MH Airstream Motorhome Forums 3 10-25-2002 03:58 PM
Battery Dead/Power jack question jcanavera Jacks, Stabilizers, Lifting and Leveling 34 08-16-2002 02:51 PM
Auto Battery problems.... kzener40 Airstream Motorhome Forums 10 08-05-2002 07:37 PM
New battery selector switch FrankR Electrical - Systems, Generators, Batteries & Solar 0 03-27-2002 11:29 PM
