Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Safari > 2004 Safari
Old 01-30-2008, 10:00 AM   #15
BIGED52's Avatar
Profile:  1967 22' Safari
MILAN , Illinois
Lewster, I stand corrected! I knew it had to do with the moisture content in the air but was unaware that you could speed up the process of curing by actually using a fine mist spray. I will tuck that away for the next time I seal seams. Thanks for the tip. Happy Trails, Ed
1967 Safari Twin "Landshark" w/International trim package
1999 GMC Sierra 1500 SLT
FORUMS MEMBER SINCE 12/16/2004
AIR#7110
"My tire was thumping, I thought it was flat!
When I looked at the tire... I noticed your CAT!"
Burma Shave
BIGED52 is offline   Reply With Quote
Old 01-30-2008, 05:18 PM   #16
Commercial Vendor
lewster's Avatar
Profile:  2006 19' International CCD
Marco Island, FL , Hood River, OR
BTW, This supposed to be a SECRET TIP!!!!!
Lew Farber - contact
Certified Master RV Tech
BACK IN THE 'HOOD' FOR A WHILE !!
"Laissez Les Bon Temps Roulez"
www.islandmetalworks.com
WBCCI #1032/VAC (assoc) #1032
AIR # 10325
CHARTER MEMBER: FOUR CORNERS UNIT
Old 01-31-2008, 12:55 PM   #17
BIGED52's Avatar
MILAN , Illinois
Crap!!!!
Now I'll be on "Double Secret Airstream Probation!!!" I hate it when that happens! Ed
AIR#7110
Burma Shave
Old 02-14-2008, 09:17 AM   #18
Aluminut
Silvertwinkie's Avatar
Profile:  2004 25' Safari
Northern Suburbs , Illinois
Ok, I got a response back from the factory. Installing the big front window and a the rear window are possible, but as for budget, that may be as far as I go this round, if I were to do it. I know that Rich Luhr had one of his replaced by a dealer, but one thing the factory said was that they have never done this before, which kind of gives me pause. Justified?
Old 02-14-2008, 10:18 PM   #19
BIGED52's Avatar
MILAN , Illinois
Conversion
Twink, That the factory said they have never done this before means your idea is a Custom job... no more no less! The fact that they said it could be done and that Rich L. had one done by a dealer means it is feasible and certainly can work out. I think your justification is the benefit you will get from the higher quality and better function of those windows vs. what you have now. I would say if your budget allows... GO FOR IT! Only you can justify the expense but think of your unique fix for problematic window issues. You will most likely have a better seal of the windows in the body of the trailer and better trimout if the JC factory folks do the work. I for one like your solution for better air flow in the trailer by using these windows and it would certainly make your trailer one of a kind. Happy Trails, Ed
AIR#7110
Burma Shave
Pingbacks are On
PEX Conversion Sundance Fresh Water Systems 18 07-12-2007 04:12 PM
30 to 50 amp conversion Honkity Hank Classic Motorhomes 25 03-29-2006 08:51 PM
Airstream Rv Conversion Zed2 Our Community 2 06-14-2004 01:17 PM
50 Amp Conversion? Gunnyusmc Electrical - Systems, Generators, Batteries & Solar 7 06-02-2004 10:56 AM
AC conversion jaiman Mechanics Corner - Engines, Transmission & More... 9 09-04-2003 02:22 PM
SEO by vBSEO 3.1.0
