Join Airstream Forums Today
Old 07-31-2011, 12:56 PM   #1
2004 28' Safari S/O
Livingston , Louisiana
Toilet room
2004 28' Safari SO (slide out). The normal siting position on the toilet does not allow enough knee room. Sit side ways and knees don't hit cabnet but no comfort. As yet to turn the bowl to increase comfort but still not much knee room. Was told to just leave the door open, still no comfort. Thinking about altering the cabnet to allow more knee room. Any help?
david686 is offline   Reply With Quote
Old 07-31-2011, 02:41 PM   #2
fmrcaptevil's Avatar
2012 30' International
Livingston , Texas
I feel your.....knee pain? I had the same problem, and solved it by going to a Dometic (Sea/Land) Traveler Lite toilet, model 210. They're constructed in such a way that the "base" portion (which bolts to the floor), is attached to the bowl with a huge band clamp, which tightens via a worm gear (similar to automotive hose clamps). That allows you to offset the bowl a few degrees left or right of center, relative to the base. That may give you just enough room on the vanity side, but you may still have to crack the door....(I still do, but that's O.K., Airstreams are worth it!) Also, the base portion is made of black plastic, so it's less disgusting whenever anyone happens to glance down there when flushing. And, it'll accept a standard residential seat. The things I don't like about it are 1), the seals between the flush ball and the bowl have to be cleaned quite frequently, or it won't hold water (they even include a little thingy that looks like a tongue depressor to assist you...how thoughtful!), and 2), the bowl "coverage" they brag about is, in reality, pathetic. So it's far from perfect, but it beats the Thetford "Aqua Torture Five" that the factory usually imposes on us.
fmrcaptevil is offline   Reply With Quote
Thetford Style II toilet model 42059/replacing Lothlorian Sinks, Showers & Toilets 4 08-23-2011 05:07 PM
How do I find the correct replacement toilet? meredith Sinks, Showers & Toilets 1 07-15-2011 12:20 AM
Toilet over laminate? willbrackman Floor Finishes 0 07-11-2011 12:31 PM
Toilet height- too high? SalandViv Sinks, Showers & Toilets 5 05-08-2011 11:06 AM
composite flooring bathroom installation sealing the toilet handn Floor Finishes 1 03-10-2011 06:47 PM
