Old 07-21-2018, 10:26 AM   #1
JMB11's Avatar
2004 25' Safari
Ormond Beach , Florida
Solar Prewire
There are a pair of what appear to be #8 green and yellow wires inside the refrigerator compartment door of my 2004 Safari SS. First, please confirm these are in fact for solar pre-wire and if so, where does the other end of these wires terminate ? I realize if they are pre-wire they're undersized and will need to be upsized to at least #6 or larger.
JMB11 is offline   Reply With Quote
Old 07-21-2018, 11:02 AM   #2
Half a Rivet Short
Carlisle , Pennsylvania
Hi
The other end *should* terminate on the roof in a box if it's like the more recent trailers.
Unless you are going crazy with panels, the stock number 10 wire will do fine. You are coming down from the roof at 16 to 18 volts. With 160W of panels, that's at or below 10A. Number 10 is one miliohm per foot. If you have a 40' round trip, that's 0.04 ohms. At 10A you will have a drop of 0.4V. Out of your 16V, that's 2.5% at full load. At lower loads, the loss will be less. Maximum rating wise, number 10 is generally considered to be good for 30A.
Since you don't have a controller yet, if you *are* going crazy with panels, run them in series / parallel. ( or get panels that put out 32 to 36V). Then your current is halved for the same power output. Something like a Victron MPPT 75 or 100 unit will be perfectly happy with the higher voltage input.
Old 10-17-2018, 09:38 PM   #3
Eric
tucson , Arizona
Hi .. I have a Safari 23 2006 .. any idea where i can find the end of the solar pre-wire?I do see cables behind fridge .. Thank you,
Eric
laferic is offline   Reply With Quote
Old 10-17-2018, 09:44 PM   #4
Eric
tucson , Arizona
Did you find the cable ends?
Thx ..Eric
Old 10-18-2018, 05:13 AM   #5
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
An '06? Try removing the interior garnish from around the roof vents, you should see a yellow and a green wire set tucked up inside one of them.
Old 03-02-2019, 01:55 PM   #6
JMB11's Avatar
2004 25' Safari
Thx ..Eric
Eric,
I apologize. For some reason, I never saw your question. I only found prewire in refrigerator compartment but not the other end. I did remove front fan trim but couldn't find the prewire there. Did you ever find it ?
solar prewire location: 2007 20' Safari SE DBULL Electrical - Systems, Generators, Batteries & Solar 2 10-21-2012 10:01 PM
Solar Prewire - 2005 Safari, 22 ft jsutro Generators & Solar Power 18 04-06-2012 01:29 PM
Solar Battery Charger Prewire t7389sg Classic Motorhomes 0 08-18-2011 08:01 AM
solar/use prewire? billiards Generators & Solar Power 4 07-30-2008 01:54 PM
Solar Prewire, What Does It Mean? dottie dawglips Generators & Solar Power 6 08-06-2003 07:30 PM
