Old 12-10-2003, 08:22 AM   #15
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
Be carful on the Walmart Extension Cord. The wire size may be marginal for the application. Bigger is better. I always buy my 30 AMP cords from CW.
The rest of it is normally equal, WM=CW but this is one issue that I have discussed with other members.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 12-10-2003, 08:33 AM   #16
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Maybe I missed thread. Are you guys saying the 30 amp RV cord sold by Walmart isn't 30 amp????
Jack
Jack Canavera
STL Mo.
AIR #56
Old 12-10-2003, 08:54 AM   #17
Just a member
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
I don't remember the numbers off the top of my head, but John_HD and I were talking about the wire sizes and the 30 Amp cord is the proper size wire, but just barley if you factor in the length and line loss. As I remember it is one wire size smaller than the cord available at CW. You would need to get the numbers off the wire jacket to be sure of the sizes. I can check mine tonight and post them. I have 2 extension cords, both from CW. One is supposed to be sacrificed to replace my coach power cord as the end of the cord is going bad, but for right now it is the one I leave in the garage for quick hook ups.
Brett G
Old 12-10-2003, 09:01 AM   #18
jcanavera's Avatar
Fenton , Missouri
Images: 143
I'm not postive but I'm pretty sure I did buy mine from Walmart shortly after I bought the Safari a couple of years ago. I think I have only had to use it once. I would assume that if the cord is UL rated, doesn't that mean it should handle 30 amps? I think its 25 feet long.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 12-10-2003, 06:33 PM   #19
Just a member
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
Jack,
Just checked my extension cord. It has stamped into the PVC jacket. 10 AWG 3C Recreational vehicle power cord 30 amps.
I want to say that some of the ones seen at Wally World were 12 AWG?
Brett G
Old 12-10-2003, 07:05 PM   #20
87MH's Avatar
1978 31' Sovereign
Images: 292
Voltage Losses
A 30 amp load through 50 feet of 12 gauge wire will only deliver 114 volts to the circuit breaker from a 120 volt plug. A 6% loss.
The same 30 amp load (50') through a 10 guage wire delivers 116 volts. A 3% loss.
Even though it doesn't seem like much of a difference, the 12 guage wire is at the ragged edge of heating up, creating more internal resistance, and really causing major voltage drops.
The above, coupled with the fact that on peak weekends most campgrounds have difficulty delivering even 117 volts at each campsite, really demands a minimum of 10 guage wire for lead-in service.
I discovered this past summer how much a new AC costs due to blowing the original AC due to inappropriate voltage.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Old 12-11-2003, 07:32 AM   #21
jcanavera's Avatar
Fenton , Missouri
Images: 143
I have an analog voltage monitor that I keep plugged into a kitchen outlet. I watch this fairly closely to make sure I don't get myself into trouble.
It the trailer umbilicle 10 gauge?
Jack
Jack Canavera
STL Mo.
AIR #56
Old 12-11-2003, 08:49 AM   #22
87MH's Avatar
1978 31' Sovereign
Images: 292
Umbilical Gauge
I just checked the service manual for the 345. Amazingly, no guage is given for the actual umbilical, neither is it embossed on the actual cable sheath.
The manual did, however, indicate that 10 ga. wire was used for the jumper from the umbilical reel connection to the main breaker box.
Dennis
WBCCI # 1113
AirForums #1737
Old 12-11-2003, 12:21 PM   #23
jcanavera's Avatar
Fenton , Missouri
Images: 143
I'm going to be visiting my storage location this weekend to move the Classic. Apparently I parked in the wrong spot. I'll check the gauge out and also look at my extension. Hopefully I will find them both 10.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 01-17-2004, 01:38 PM   #24
2004 25' Safari
South West , USA
Gloves for Sewer Hook-ups
Don't forget a box of latex gloves for hooking up and dis-connecting your sewer hoses. We also like to have a few "Mike's Hd. Lemonades" handy!
RivetED is offline   Reply With Quote
Old 01-17-2004, 07:24 PM   #25
dpope's Avatar
Send a message via Yahoo to dpope
We bought a small double step ladder so we can reach the awning hold downs. I got tired of using that long rod to unscrew the hold downs. It's a lot easier just to stand on the ladder and screw/unscrew them by hand.
2003 25' Safai LS (6-Sleeper) -
2003 Dodge Ram 4x4 Quad Cab Cummins Turbo Diesel High Output/Automatic Transmission. -
dpope is offline   Reply With Quote
Old 01-17-2004, 08:04 PM   #26
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
wire size calculator
hey gang,
missed the part about the extension cords.
here is a handy site for calculating wire size for minimum voltage drop.
http://www.pljohnson.com/electrical/...voltdrop.shtml
john
you call them ferrets, i call them weasels.
