Old 08-23-2018, 11:26 AM   #1
2014 Interstate Coach
Arroyo Grande & Central Point , California & Oregon
XM Antenna
Where is the XM antenna located on the AI's?
Bill
c21bill is offline   Reply With Quote
Old 08-23-2018, 12:38 PM   #2
Wannabe RV'er in training
Alex AVI's Avatar
2018 Interstate Lounge Ext
High Desert , Las Vegas , Nevada
Not sure if all MY & models have in same spot. Mine is 2018 AI Lounge built on 2017 Sprinter.
Alex AVI is offline   Reply With Quote
Old 08-23-2018, 12:51 PM   #3
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
My 2013 has it near same spot, about a foot farther forward. Also mine is a mushroom shaped antenna.
- - Mike
Old 08-23-2018, 07:48 PM   #4
I had a 14 AI which I have since traded in on a Leisure Unity. My recollection is that my xm antenna was near the windshield on the right side of the dash. Seemed to work good there. In my Unity I placed it by the windshield at the center of the dash and I have a lot of intermittent signal loss. May try moving it to where I think it was in my AI. Ideal would be on the roof but seems like a daunting task to route the wire.
Thanks for the feedback
Old 08-23-2018, 09:46 PM   #5
rowiebowie's Avatar
2012 Avenue Coach
Corpus Christi , Texas
On my 2012 Avenue it is a domed antenna rather than the flat puck shape on the newer models.
It sits just ahead and to the right of my gigantic flexible solar panel.
Look closely and it says "GALAXY" & "Sirius"
rowiebowie is offline   Reply With Quote
Old 08-23-2018, 10:25 PM   #6
Alex AVI's Avatar
ROWIEBOWIE - actually on my MY the shape is a hybrid between dome (lower half) & puck (flat top). Sorta like someone at Sirius swung a ginzu knife on the mushroom head. It nice to have a gigantic solar panel, yet is still very inconspicuous
Old 08-23-2018, 10:30 PM   #7
WillieJ's Avatar
Bellingham , Washington
XM antenna
Bill
2013 AI. Mine is magnetically attached to a metal plate in the passenger side on the dash. It is identical to the other magnetic mount XM antennas I have for other satellite radios I own.
I have a mushroom type antenna on the roof, but that is the gps antenna.
WillieJ is offline   Reply With Quote
Old 08-24-2018, 12:23 AM   #8
rowiebowie's Avatar
2012 Avenue Coach
Well see, I was thinking it was just the opposite. My little roof half dome says Sirius on it. See my pic in post #5.
Old 08-24-2018, 12:27 AM   #9
rowiebowie's Avatar
2012 Avenue Coach
I zoomed in on your picture. Your little mush-puck says "GALAXY" and "Sirius" like mine.
Old 08-24-2018, 01:02 AM   #10
Alex AVI's Avatar
ROWIEBOWIE - I think I figured out why mine is a mush-puck . . . the newer sat dishes are now flattops instead of mushroom. So Sirius figured they need to go flattop instead of mushroom too
WILLIEJ - that's strange that they put your XM antenna inside windshield and GPS on roof. Of the two, XM radio needs the better signal, GPS can usually locate even inside the van. General install recommendations are to put on a good ground plane and I think on a metal surface (not 100% sure of this though). But sight line could be compromised if inside windshield if you are driving northbound since the roof of van will block antenna from south. XM would need to narrow down the exact signal spectrum from a private comm sat. But GPS signals on other hand connect to at least 3, 4, or even 9 location sats to deliver longtitue, latitude, & movement. Any issues with XM recep ?
Old 08-24-2018, 09:19 AM   #11
WillieJ's Avatar
The only reception issues have been in the area of heavier tree cover, where the sat radio in my Audi also cuts out.
Old 08-24-2018, 10:22 AM   #12
Fulton , Maryland
WILLIEJ - I think you have it backwards. I also have a 2013 Interstate and the mushroom antenna on roof is for SiriuXM. Magnetic antenna on RH side of dash is for the Kenwood/Garmin GPS.
- - Mike
Old 08-24-2018, 06:20 PM   #13
I bit the bullet and ordered a marine grade xm antenna and I'll try the Geek Squad at best buy to install. Hope it works out satisfactorily.
Old 08-24-2018, 10:48 PM   #14
WillieJ's Avatar
You are quite correct. I have the manual for the 2015 AI and the wire routing diagram shows GPS on the dash, and the Sirius XM antenna on the roof. The GPS antenna is remarkably similar to the XM magnetic mount antennae supplied with some of the mobile add on XM radios and I made an incorrect assumption.
The 2015 wiring diagram has proved to be very accurate for my late production 2013 AI.
Old 08-24-2018, 11:09 PM   #15
Fulton , Maryland
Agree the 2015 wiring diagrams are very close to our 2013 Interstates. Also here is page from the Kenwood installation manual that shows how to locate the GPS antenna on dash.
- - Mike
Old 08-24-2018, 11:13 PM   #16
Fulton , Maryland
C21BILL - curious about what happened to the SiriusXM antenna that should have come with your 2014 Interstate? Thought all Interstates since about 2010 came with SiriusXM installed.
- - Mike
Old 08-25-2018, 04:18 AM   #17
Nothing happened to it. I traded the AI in on my new Leisure Unity and forgot where the xm antenna was located. Leisure's don't come with an xm antenna installed. I installed a portable xm radio on my Unity that plays thru the in-dash radio. For now the antenna is laying on the dash but I do experience a lot of intermittent signal loss. I just don't relish the idea of trying to route the antenna lead from the roof to the dash so I'll give Geek Squad a try.
Attached photo shows my portable XM Radio. Upper bracket is for my Garmin RV 760. (whoops, tilt your head 90 degrees to the left to view my picture).
Name:	GPS Mount.jpg
Old 08-25-2018, 09:46 PM   #18
Fulton , Maryland
C21BILL - thanks for clarifying. I forget that you switched to an LTV Unity.
- - Mike
Pulling the Air TV Antenna Replace With A Satellite Antenna Chuhhuniban Electronics & Connectivity 11 04-03-2019 08:11 AM
Antenna Removal & Replacement with Cell/Wifi Antenna BoldAdventure Electronics & Connectivity 10 08-14-2017 08:24 AM
Rooftop Antenna Installation - Spring Mount Cellular Antenna Astw Electronics & Connectivity 4 08-04-2016 09:51 AM
Motorized TV Antenna Crystaljean22 Mechanics Corner - Engines, Transmission & More... 8 07-16-2007 11:30 AM
TV Antenna wiring??? tenrsingr Audio, Video & TV 6 05-06-2002 03:16 PM
