Old 07-29-2015, 03:41 PM   #1
2014 Interstate Ext. Coach
fairfax station , va
Winterizing Flojet
The interstate has a Flojet water pump with quad port connections behind the drawer under the microwave.
I was going to install a 3-way Camco winterizing valve on mine for pumping antifreeze.
The valve is kind of low quality and the 'internet" is "disappointed" that it is not 'full flow' and reduces the 1/2" flow to less than 3/8" all of the time.
When examining the actual pump location it appears that installation would be extremely difficult (if not impossible) because of lack of space and an unfortunate waste pipe that obstructs the inlet hose.
I thought how about this.
The quad-port is a sliding collar and push quick connect fitting.
Maybe it would be easier just to get a quad port elbow, put whatever length of hose on it that I want and switch it out with the inlet fitting once per year.
OK, that was long winded....
Has anybody ever done this? Does it work?
VAtom is offline   Reply With Quote
Old 07-29-2015, 05:53 PM   #2
2011 Interstate Coach
Muskogee , Oklahoma
Why not just pour a couple of gallons of the red stuff in the fresh water tank and run the pump? That works for me.
2011 Interstate WD/Lounge
gmillerok1 is offline   Reply With Quote
Old 07-29-2015, 06:10 PM   #3
toskeysam's Avatar
2013 Interstate Coach
Townsend , Tennessee
The elbow and 2' of tubing is exactly what I did....works great.
Got the fittings on Amazon.
FMCA # 436814
toskeysam is offline   Reply With Quote
Old 07-29-2015, 06:13 PM   #4
Full time Airstreamer
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
Anywhere , USA Living.Somewhere.Yonder
Brilliant!
@living.somewhere.yonder | Instagram
SCOTTinNJ is offline   Reply With Quote
Old 07-29-2015, 06:19 PM   #5
antifreeze in fresh water tank
Well, currently, a lot of people think that your method wastes too much antifreeze and contaminates the fresh water tank so that it needs excess purging in the spring. They may or may not be right.
Draining the tank and treating only downstream of the pump has become standard practice. That's why Camco makes the bypass valve.
I was just interested if anyone had just eliminated the bypass valve and filled directly from the inlet using a quad port connector.
Apparently that's just what Toskeysam did...thanks for the info Toskey.
Old 07-29-2015, 07:42 PM   #6
toskeysam's Avatar
The only downside of the elbow/tube method is the location of the pump makes the task a real knuckle-buster.
FMCA # 436814
Old 07-29-2015, 07:44 PM   #7
toskeysam's Avatar
I really liked one person's suggestion to use a couple bottles of cheap vodka in the tank, but haven't tried that 😊.
FMCA # 436814
Old 07-29-2015, 07:51 PM   #8
Muskogee , Oklahoma
Never been a problem in 8 years so far....at a couple of bucks a gallon, it's not going to break the bank. In the spring, I just do the normal sanitize, flush and repeat. Never had a problem with that, either.
Old 07-29-2015, 07:53 PM   #9
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Where you live in Tennessee you can probably get away with that— as long as you don't take your Airstream to a dry county while it's winterized… 80-proof vodka freezes at -16°F and as far as I know Tennessee doesn't usually get that cold.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 07-29-2015, 08:50 PM   #10
toskeysam's Avatar
Could add a new dimension to "Spring Break" when I dewinterize 😎
FMCA # 436814
Flojet RV Waste Pump Kit Dr. E Waste Systems, Tanks & Totes 12 10-01-2017 04:17 PM
New pump head for Flojet 4000 series? 3Ms75Argosy Water Heaters, Filters & Pumps 1 05-07-2010 04:24 PM
FloJet VSD Water Pump Airstream 65 Water Heaters, Filters & Pumps 14 03-31-2007 11:21 AM
FloJet Waste Pump Roadtoaster Waste Systems, Tanks & Totes 0 08-14-2006 09:12 AM
Just Installed Flojet Waste Pump wa3vez Mechanics Corner - Engines, Transmission & More... 2 10-24-2004 09:46 AM
