Old 12-25-2015, 11:14 AM   #1
weirdstuff's Avatar
2018 23' International
San Diego , California
Winterize van if not using water?
If I'm not gonna use the water/toilet, etc. in my Interstate, and it's in the 30's at night, am I at risk for bursting a pipe or anything?
Might be driving to Phoenix, and it looks like it's in the 30's at night, and mid to high 50's during the day.
Probably staying w/ relatives, so don't need to use water in van. But, want to be sure nothing bad will happen. Alternative is to just drive our car.
Southern Californian....no idea what to do when it drops below 55!!
weirdstuff is offline   Reply With Quote
Old 12-25-2015, 11:21 AM   #2
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
Water won't freeze unless 32' or below I, in side it probably wouldn't start to freeze until 25' or so.
Old 12-25-2015, 11:29 AM   #3
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
With my trailer I probably would not winterize and would use the water. Because I know if it gets cold the propane furnace will keep it from freezing. Does the van have a heater that will run overnight and keep the pipes from freezing when it is parked if you do hit a cold spell?
Old 12-25-2015, 11:39 AM   #4
2005 19' Safari
GLENDALE , AZ
Forecast for today (12/25/15) is 60/35 degrees (day/night).
We don't winterize or worry about pipes freezing until overnight lows drop into the teens, and daytime temps are consistently in the low-20's (which does not occur in Phoenix).
I would not worry about cold weather unless your route includes an overnight stay in an area with the subfreezing conditions described above.
Old 12-25-2015, 11:42 AM   #5
weirdstuff's Avatar
OK. Thanks. Sounds like we'll be fine. Was just a last minute thought that popped into my brain, so wanted to be sure.
Old 12-25-2015, 11:56 AM   #6
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Since you posted the same question on the "Are We Crazy" thread, please see that thread for my response.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 12-25-2015, 01:07 PM   #7
weirdstuff's Avatar
Got it. Thanks.
Sorry for double post. Wanted to be sure someone saw it today!
Using a vacuum pump to de-winterize BicenTw Winterizing, Storage, Carports & Covers 12 10-20-2015 11:10 AM
first full winter - plan to NOT winterize Anders79 2009-2015 Flying Cloud 14 09-23-2015 03:23 PM
Cold nights ahead but I'd rather not winterize. Best option? blickcd Winterizing, Storage, Carports & Covers 20 10-07-2012 05:17 PM
husband did not winterize BessieB Fresh Water Systems 45 07-17-2010 10:47 AM
Winterize: Water htr- drain or not?? crazylev Winterizing, Storage, Carports & Covers 17 09-24-2005 01:14 PM
