Old 01-05-2015, 10:07 PM   #21
2012 Interstate Coach
norman , Oklahoma
If you run the tank heaters while you are driving the alternator will keep the batteries up no problem. Turn them off when you stop and you should be able to get through the nights without them freezing up (unless it's really cold). It takes a long time for a big tank of water to freeze. You could dump some antifreeze in the grey tank (just pour it down the sink). The black tank will be fine inside with you at a comfortable temp. In my experience with a full load (rooftop a/c on high) the generator will blow through the propane tank in about 36 hours of run time. But you should only need to run the genny if your using the microwave or coffee pot so that should not be a factor. Even if you run it to keep the tank heaters on at night they won't put nearly the load on the system that the a/c does (perhaps 6 amps vs 15 for the a/c). The furnace and hot water heater (running only on propane) use so little fuel that I can't even begin to tell you how long it will last. I would guess that you would get at least a week out of your propane supply just to run the furnace and water heater. One of the truck stop chains (Flyin J or Pilot?) has propane at many of their stores (though not all). Your can use the GPS to search for them by name along your route and it will also provide their phone numbers so you can call ahead and verify availability. Also most U-haul locations have propane and those are also easily searchable on the GPS. Note that for most of us, our propane level gauge is notoriously pessimistic. Run it down to where you feel comfortable the first time then note how much (or how little) propane it takes to fill it up. For our 15 gallon LPG tanks, you can only fill to 80% so when it's truly empty it should take about 12 gallons to fill it up. IIRC when my gauge first hits empty it only takes about 8 gals to fill it up. That was after running the generator for about 24 hours. In a later trial I got to the about the 36 hour mark before the generator actually sputtered to a stop (well after the gauge told me it was empty). Your mileage may vary. Good luck and safe travels!
russ240 is offline   Reply With Quote
Old 01-06-2015, 12:12 AM   #22
Len and Jeanne
Len n Jeanne's Avatar
2005 16' International CCD
2015 19' Flying Cloud
Creston Valley , British Columbia
Winterizing your AS (water drained, pipes blown out, antifreeze added) can make it inconvenient to travel in, but a lot less inconvenient than bursting a water pipe. With an electrical hookup, you can save your propane by running a small space-heater inside and piling on the covers. Take a lot of water bottles for your water uses, such as a manual toilet flush, and put an anti-freezer chaser (like windshield washer fluid) down the toilet or sink after your waste-water.
Len n Jeanne is offline   Reply With Quote
Old 01-06-2015, 07:43 AM   #23
2013 Interstate Coach
Flemington , New Jersey
With proper winterization you're good to some pretty low temps.
If you feel comfortable operating the generator and furnace, the coach can be made quite cozy in the cold.
Camped in my winterized Interstate the weekend before Thanksgiving in a race track paddock (lime rock park in CT). I even ran out of propane (finally) and discovered my propane level sensors are very inaccurate (even when empty it reads full, LOL). Now I know that I can get about 28hours of mixed propane use from that tank.
Oh, yeah, during one of my two nights at the race track, I ran out of propane about 2 hours before I went to bed (was 22 outside) and when I woke up in the morning the inside of the coach was 17 degrees! Glad I brought some heavy wool blankets. With no propane to run the genset and the furnace I had to resort to using the cab heater to warm the inside.
A winterized bathroom will call for some strategic planning for when nature calls.
Mario
2013 Interstate
2014 Little Guy 5x10 Silver Shadow
Tiato is offline   Reply With Quote
Old 01-06-2015, 09:11 AM   #24
UKDUDE's Avatar
2014 Interstate Ext. Coach
Sedona , Arizona
So a really comprehensive backup kit should also include a few of those mini propane cylinders, a propane stove, and a propane catalytic heater.
Old 01-07-2015, 02:26 AM   #25
norman , Oklahoma
Wow, I'm shocked by how short that is. I've let my AI sit in the driveway non-winterized for weeks with the furnace on 50 and had insignificant use of propane. Also dry camped in it three nights in temps in the 20's (cabin temp at 65) also without making a dent in the propane level. I'm left wondering why your use was so different? Were you running the generator much? In my experience the generator sucks the fuel down at many times the rate of the furnace and hot water tank. Curious ....
Old 01-07-2015, 09:15 AM   #26
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
How do you keep your macerator pump from freezing?
2011 Interstate SOLD! Upfitted 2017 Transit 350. SOLD!
Old 01-07-2015, 09:32 AM   #27
toskeysam's Avatar
Townsend , Tennessee
We've taken a couple of different paths.
First time out, while "winterized", we took bottled water, plastic toilet liners,kitty litter. Used the KOA bathrooms during the day, and the liner with a couple handfuls of kitty-litter for those middle of the night trips. (Not ideal, but sure beat opening the door in the icy cold.)
Second time out, we filled everything below the floor wth antifreeze. Then used the water system as usual...with tank heaters on!!! Of course this uses a lot of antifreeze (essentially winterizing everytime you would dump). Worked, but not sure how practical it is.
FMCA # 436814
toskeysam is offline   Reply With Quote
Old 01-07-2015, 11:45 AM   #28
28 hours of generator use. The last 10 hours were generator and furnace simultaneously. The 28 hours of propane lasted 13 months though.
If I were to add up all the furnace use while plugged in, it wouldn't be more than 5 - 7 hours.
Used the water heater maybe once.
Figure 35 hours out the tank.
Mario
2013 Interstate
Old 01-07-2015, 04:03 PM   #29
norman , Oklahoma
Ah, now it makes sense. Running the genny to keep the tank heaters on I presume? That would certainly account for the difference vs. my experience. The furnace and water heater just don't burn my propane relative to the generator.
With regards to the macerator pump ... I have to admit that at the time I did not even think about it and somehow did not have any trouble. Since then I have adopted the practice of dumping the tanks, then adding antifreeze and dumping again so that the sewage lines are all protected.
Old 01-07-2015, 05:47 PM   #30
Boxster1971's Avatar
2024 Interstate 19
Fulton , Maryland
When I run in winterized mode we take bottled water and use RV anti-freeze to flush the toilet. Seems to work well.
- - Mike
2013 Lounge EXT on 2012 Sprinter
- - Mike
2024 Airstream Interstate 19e AWD
Previous: 2013 Airstream Interstate 3500 Ext Lounge
Wanted: Vintage Travel Trailer in exchange for a winter stay in sunny Tucson, Arizona KateMcKinnon Winter Living 0 08-04-2009 09:30 AM
Northwest winter travel msmst25 Winter Living 14 11-28-2007 06:22 PM
Winter travel imagine Winter Living 12 08-13-2006 01:20 PM
Winter? What winter??? Pahaska Off Topic Forum 21 01-06-2006 09:17 AM
Winter travel? 63air Winter Living 12 12-01-2005 10:42 AM
