Old 10-22-2015, 10:49 AM   #15
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Originally Posted by gmillerok1 View Post
When the tank is emptied, there is about two or three gallons of water or more that never empties that is left in the 3" pvc pipe from the tanks to the macerator.
One foot of 3" pipe holds 0.3 gallons of water. I suspect the amount of water retained in the pipes between the black and gray tanks and the macerator pump is less than a gallon, because even if the pipes are completely full they'd only hold about 3 gallons, and they're not completely full anymore by the time the macerator pump starts sucking air.
But your point is well taken anyway. Make extensive use of your black tank flush fitting so that the macerator pump is pumping clear water from the black tank before you winterize; you don't want black water spilling out the connection when you drain the 3" pipe— especially since you have to crawl underneath to do it and getting a face-full of black water by accident would be a crapload of no fun.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Protagonist is online now   Reply With Quote
Old 10-22-2015, 12:34 PM   #16
2011 Interstate Coach
Muskogee , Oklahoma
There's at least six feet of pipe there, if not more. When I open up the cap, I'm really amazed how much pours out. It goes on for quite a while and takes several minutes to completely drain out. Because the bottom of the pipe is on the same level as the bottom of the tank, I think what is occurring is that liquid in the tanks is also not completely draining out after the air/liquid mix starts in. I may just take a five gallon bucket and measure it next time to see.
2011 Interstate WD/Lounge
gmillerok1 is offline   Reply With Quote
Old 10-22-2015, 03:08 PM   #17
Muskogee , Oklahoma
To show why there is so much water held in the pipe, take a look at the way the plumbing is designed. The grey tank has a very large horizontal surface and since it mostly stops pushing water out the hose after air enters the pump, that's where it stays. As you can see from the schematic, a very large surface in the tank will also hold water if the valve is open. Plus, there's more like 6 to 8 feet of pipe, even if you close the valve.
So, that's why it's more likely to be closer to 2 or 3 gallons or more and why antifreeze in severe winters likely won't (and wasn't) enough to protect the pump.
Old 10-22-2015, 06:02 PM   #18
Here's a thought… If you use some leveling blocks to un-level the van by raising the passenger side when dumping, that might help.
WBCCI #1105
TAC LA-4
Old 10-22-2015, 06:35 PM   #19
toskeysam's Avatar
2013 Interstate Coach
Townsend , Tennessee
I have a place where I can park the passenger side as the high side. It seems to help dramatically. I pumped from level and pumped again when tilted.....wow what a difference.
FMCA # 436814
toskeysam is offline   Reply With Quote
Winter Visitor Coming to Florida Anyway? Mary Burris Full-Timing, Winter Living & Workamping 2 11-28-2012 07:16 PM
Winter is coming to Texas...LOL THEPILL Our Community 15 11-24-2010 09:35 AM
The welder is coming, the welder is coming... Safari Tim General Interior Topics 13 09-01-2006 10:00 AM
Winter? What winter??? Pahaska Off Topic Forum 21 01-06-2006 09:17 AM
The Airstreams are Coming!! The Airstreams are Coming!! j54mark Airstream "In the News" 7 07-07-2005 07:06 AM
