Old 12-06-2015, 03:24 PM   #1
Windy driving conditions
Hi. I have a 2015 airstream extended grand tour and I love it. My question is about driving- on a recent trip we had crosswinds for hours which created white knuckled driving. I'd go thru an underpass and have to hold the steering wheel one way, come out of the underpass and quickly have to jerk it the other way. I would appreciate any suggestions to solve this problem without having to go to an air system- example: any away bars that may work or shocks that might work.
P.S.- also i tow a 2015 jeep rubicon 4 door which can feel at times like the tail wagging the dog.
Thanks for any help.
eason is offline   Reply With Quote
Old 12-06-2015, 04:00 PM   #2
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
How fast are you driving with heavy cross-winds? These vans are a big sail area and the best solution I can offer from experience is to slow down a bit to about 55-60 in high cross-winds.
That Jeep Rubicon is just another box behind you adding to the problem.
- - Mike
2013 Lounge EXT on 2012 Sprinter
- - Mike
Old 12-06-2015, 04:12 PM   #3
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
I found my air bags for the front springs, tire pressures, and speed amplified wind movements. In previous van mh I solved it by installing a steering damper or shock absorber. Looking at the sprinter profile I would suggest removing all weight from high cabinets, filling the water tanks. Maybe Protag as an engineer can offer better solutions.
Old 12-06-2015, 04:15 PM   #4
UKDUDE's Avatar
2014 Interstate Ext. Coach
Sedona , Arizona
It's a problem with all Sprinters, and I think I remember my local dealer telling me they are installing some technical wizardry to reduce the effects of cross winds. Applying braking to the diagonally opposite rear wheel, or something like that. More to go wrong in my opinion. Just drive slower.
Old 12-06-2015, 04:53 PM   #5
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
Just noticed it is your first post, Welcome to the land of information.
Old 12-06-2015, 06:25 PM   #6
Ron_CA's Avatar
2015 Interstate Ext. Coach
San Diego , California
Let me guess...New Mexico or Texas?
I have experienced major winds for hundreds of miles and it definitely takes a toll on the driver. Like others have said, just slow down a bit and you should be fine.
Ron_CA is offline   Reply With Quote
Old 12-06-2015, 06:31 PM   #7
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Okay, let's see… A Jeep Wrangler Unlimited Rubicon has a GVWR of 5700 pounds, in excess of a Grand Tour's towing capacity. The curb weight is 4500 pounds, so if you're carrying any cargo more than than a full tank of fuel in it (fuel is considered part of curb weight) you're pushing the limit of your Grand Tour's towing capacity.
The Jeep has a very boxy shape, and is long enough that it doesn't fit entirely within your Interstate's slipstream. Meaning that the rear end of the Jeep is always in turbulent air. That would certainly contribute to the "tail wagging the dog" syndrome you mentioned.
One thing that should help is to get a front-end alignment done on the Grand Tour, especially if you haven't done one since buying the van. When Airstream bought the vans from Mercedes, the empty vans had the correct alignment. But that's before Airstream added a bunch of weight that may or may not be a balanced load. And Airstream does not do alignments on the vans they sell. Since a bad alignment can contribute to directional instability, getting the van realigned is pretty much the first step toward a fix, and is cheaper than other suspension improvements you could try.
From a safety standpoint, there are two "best practices" for high crosswind situations. (1) Park it and wait for the wind to die down; and (2) if you have a second driver with you, unhitch and drive each vehicle separately until the winds die down. Each vehicle by itself will be better-behaved in a crosswind than will the combination hitched together.
Given the shape of a Jeep and the shape of a Sprinter, each one will catch crosswinds more strongly at the rear of the vehicle than at the front, and they will both have a tendency to want to weathervane (point up into the wind), meaning the rear will want to veer farther than the front and steering corrections are not too difficult or scary because the van will actually help you steer in the direction you want to go.
Pin the two vehicles together at the towbar and it no longer becomes possible to predict how the combination will react to crosswinds without putting them into a wind tunnel and/or on a skidpad, but I'm thinking the Jeep will be more stable than the Sprinter because of having no overhangs to speak of, and having less surface area to catch the wind. That means the rear of the van will veer less than the front if both vehicles catch a crosswind (the exact opposite of weathervaning) as the Jeep serves as an anchor, and you need more steering correction to stay in your lane; the van will have a tendency to fight your steering corrections.
Ballasting by filling the fluid tanks and emptying the overhead lockers will not help much, except to reduce the tendency of the van to roll over as it veers. Suspension improvements other than the front-end alignment are the same. If you upgrade the rear suspension the van will not rock or lean and much as it veers, but that won't keep a crosswind from making the van veer out of its lane because you're still at the mercy of the van's surface area acting as a sail.
I have not crunched numbers on this, so everything I said is an opinion, not an analysis. If anyone out there has a different interpretation, I'd be glad to read it.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 12-06-2015, 07:17 PM   #8
Thanks for the information. On the real windy trip I wasn't pulling the jeep but I was averaging 65 mph. Slowing down would help I'm sure. I appreciate all of the input. When towing the jeep in optimal conditions it still feels like it wants to wander on me. Is that normal? Has anyone else found ways to correct this? I use a blue ox tow bar 4 wheels down towing.
Old 12-07-2015, 09:55 AM   #9
A picture tells a thousand words. Here's one of Bastrop Texas taken earlier this year. See the orientation of that jumbo flag relative to the highway? This was a 45 mph max trip for me, all the way back to Houston. No way to deal with cross winds like that, except to drive slowly.
Since that time, we have replaced our shocks and sway bar, which has improved our performance envelope somewhat. But still, we don't pretend it's a car.
Old 12-07-2015, 10:17 AM   #10
2014 Interstate Coach
Arroyo Grande & Central Point , California & Oregon
Wind has been a consideration for me although a minor one along with the sway when angling out of a driveway. I am having the Koni FSD rears installed as I write this. We just did a week long trek to San Diego (320 miles each way) and averaged 19.6 mpg down and 20.0 comming home. (63mph all the way) Needless to say I am very please with the mileage.
c21bill is offline   Reply With Quote
Old 12-07-2015, 10:42 AM   #11
Mjgman's Avatar
Bradenton , Florida
We hit really bad crosswind going through Kansas.. The wind was so bad it set off the ESP (electronic stability program).. I thought great, we are in the middle of no where with this alert flashing on the dash.. We called a dealer in Denver and she said that it would reset as soon as we turned it off.. She said many people pull into the dealership late at night and spend the night only to find out in the morning all they needed to do was get of the windy condition and reset the system..
Mjgman is offline   Reply With Quote
Old 12-07-2015, 01:21 PM   #12
Newbie
joemikeb's Avatar
Fort Worth , Texas
A set of Koni shocks and struts did wonders for the cross wind handling of my 2013 AI. But sudden heavy gusts can still be surprising and/or challenging.
Make errors — otherwise the Great Spirit realizes
you have finished your purpose on earth.
— Navajo saying
joemikeb is offline   Reply With Quote
Old 12-07-2015, 11:49 PM   #13
So, I picked up my AI with the new Koni FSD's and intentionally angled across the driveway and into the street and what an improvement. Very little rocking compared to experience with the stock shocks. It also cornered noticeably flatter. Very worthwhile investment.
Old 12-08-2015, 07:13 AM   #14
The beefier sway bar works wonders to reduce sway on the highway. But on unpaved roads it actually magnifies the ocilations making some park roads a 5 or 10 mph affair.
LB_3 is offline   Reply With Quote
Windy :: 1966 Airstream Tradewind 1966trade Airstream Registry Discussions 0 10-02-2015 02:02 AM
I've read it gets windy in South Dakota inTransit On The Road... 13 10-21-2012 02:21 PM
Road Conditions Websites Stefrobrts On The Road... 19 04-15-2007 01:53 PM
Conditions in Century, Florida from Hurricane myrnaw On The Road... 7 09-23-2004 12:19 PM
Improved Steering for windy roads scotta Airstream Motorhome Forums 3 04-01-2003 10:42 PM
