Old 03-07-2016, 12:48 PM   #1
2011 Interstate Coach
Evansville , Indiana
Windshield replacement
To reduce heat buildup in the bus, I was strongly considering getting the 3M crystalline window film installed before summer. Now I'm glad I didn't go through with it. On the way to FL a big rock hit the windshield and now there is a 12" crack. Before the incident I had not noticed that a Sprinter has a really big windshield (and probably expensive).
Anyone had any success with the "salvage" repair procedures or should we just get windshield replaced? Any advice on brands? Thanks
BurntAsphalt is offline   Reply With Quote
Old 03-07-2016, 01:59 PM   #2
UKDUDE's Avatar
2014 Interstate Ext. Coach
Sedona , Arizona
If you look closely, you'll see the windshield has an embedded heating element so fine you can hardly see it. And that makes it very expensive to replace. However, if that element is damaged, it may no longer heat the screen and you lose the ability to defog the screen quickly. Won't affect defogging with the the blower of course. Insurance usually covers a total windshield replacement.
Old 03-07-2016, 02:11 PM   #3
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Not true on units made before 2013. No windshield heating elements on the older vans.
Check insurance coverage first, and if they'll replace it on their dime, replace it. If not then I'd consider an in-situ repair of the crack, with the expectation that it might or might not be effective. If it works, you've saved a ton of money, and if it doesn't, you haven't lost much by trying.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 03-07-2016, 02:29 PM   #4
Lily&Me's Avatar
Normal , Illinois
Mine is on its 3rd windshield.
It happens.
Maggie
Lily&Me is online now   Reply With Quote
Old 03-07-2016, 03:10 PM   #5
73shark's Avatar
Overland Park , Kansas
I've had small chips repaired before they cracked and they never cracked.
Curious as to how a crack is repaired as the ads say repair before the chip turns into a crack. Inquiring minds want to know.
Old 03-07-2016, 06:02 PM   #6
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
My view - if you drive you will get windshield damage. I now have four chips in mine now after 65,000 miles. The first two were in Alaska on paved roads. Darn gravel trucks get you. Also had same thing happen in Colorado last summer. Three are so small they are nearly invisible after the repairs. The fourth is larger, about the size of a quarter, but after two years since repair it has not cracked further.
Insurance depends on your policy specifics. Mine covers total repair cost. If it needs replacement the deductible is my share.
With a 12" crack you probably need a replacement. If you have the embedded heater wires you might need to get a replacement from Mercedes. Let us know what you do and what it costs. Many of us, like me, are contemplating replacing the windshield in the future.
- - Mike
2013 Lounge EXT on 2012 Sprinter
- - Mike
Boxster1971 is online now   Reply With Quote
Old 03-07-2016, 06:05 PM   #7
Denis4x4's Avatar
Durango , Colorado
In some places, a cracked windshield is an excuse for the law to write a ticket
If you don't go first class, your heirs will!
Denis4x4 is offline   Reply With Quote
Old 03-07-2016, 08:14 PM   #8
If the crack is in the area swept by the wipers AND over a certain length, it's grounds for failing a vehicle inspection in Louisiana.
WBCCI #1105
TAC LA-4
Old 03-10-2016, 06:16 PM   #9
iaqstuff's Avatar
Yarnell , Arizona
Windshield Replacement
The windshield on our 2013 has two "heat" leads at the top. Their connection is hidden by the overhead area. We're scheduled for a replacement next week. AmFam is covering it - $0 deductible. Be glad that Sprinters have windshields with enough angle to deflect the objects up and over.
iaqstuff is offline   Reply With Quote
Old 03-10-2016, 07:26 PM   #10
Thanks for all your comments. Headed back north on Saturday so I'll soon find out how good my insurance policy is. I will give a full report on how things go. Good luck to iaqstuff on your windshield replacement as well.
Old 03-10-2016, 09:44 PM   #11
kaylorsan's Avatar
Los Gatos , California
Not true in my case. I have an early 2012 EXT with the windshield heating elements. Just goes to show that there really are a lot of variances in the AS product line; even within the same model and model year.
2012 Interstate EXT
kaylorsan is offline   Reply With Quote
Old 03-10-2016, 11:11 PM   #12
The 2012 EXT is really a 2012.5. The first production run of 2012s were non-EXT and didn't have the windshield heating elements.
This is the first I've heard that the 2012 EXT has them. I'll file that info away for future reference— assuming senility or Alzheimer's doesn't rearrange my filing system without telling me…
WBCCI #1105
TAC LA-4
Old 03-22-2016, 08:34 PM   #13
- - Mike
Following up as promised. The local windshield installer couldn't get OEM replacement (Sekurit) in my rural area so ended up with No Name glass made in China. For some reason the plain glass I got was more expensive than the heat defroster version. Quote was $825 with $250 deductible. The shop has a lifetime guarantee against leaks. Getting it installed this week.
Old 03-23-2016, 08:37 AM   #14
Fulton , Maryland
Thanks for the update - good info. I carry a $1000 deductible to keep my annual insurance cost low. Guess I'll have to pay for the windshield if I get it replaced. With four chips repaired already in 60,000 miles it's just a matter of time when I'll have to get the windshield replaced.
- - Mike
- - Mike
Cost for replacement passenger side windshield glass? Rick F General Motorhome Topics 9 09-10-2011 12:14 PM
Windshield Replacement jbsails Argosy Motorhomes 9 08-27-2009 09:06 PM
Replacement gasket for windshield kdenault Argosy Motorhomes 3 04-14-2009 11:00 AM
Replacement windshield in 345? Outside Mirror? Curtis-79MH Classic Motorhomes 2 05-17-2005 09:59 AM
