Old 09-28-2014, 05:18 PM   #1
2005 22' Interstate
N. Hollywood , California
Window washer indicator
My washer fluid indicator came on so I filled up the container and the warning light is still on.
Is there something special I need to do to reset part from filling the tank ?
Cheers
Colin
mrcolin2u is offline   Reply With Quote
Old 09-28-2014, 08:26 PM   #2
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Far as I know, just refill, start the engine, let it run for a minute or two, turn off the engine, and start the engine again. That should cause the message display to reset itself.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 09-28-2014, 09:10 PM   #3
2005 22' Interstate
I filled it on friday then drove 150 miles roundtrip , multiple stops and starts.
The lamp is still on.
I did a search on the sprinter forum and maybe disconnecting the leads to the sensor/pump then reconnecting may solve the problem.
I will try this tomorrow.
Old 09-28-2014, 10:58 PM   #4
Jeff64's Avatar
2014 Interstate Ext. Coach
Springfield , Missouri
I hate to ask a stupid question but... Is it possible that you could have filled the wrong tank?
Jeff64 is offline   Reply With Quote
Old 09-28-2014, 11:03 PM   #5
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
That could be expensive.
I didn't know that it had a low level indicator on it. I usually just top off the reservoir before each trip. Need to RTFM some more.
Old 09-29-2014, 05:06 AM   #6
2013 Interstate Coach
Raymond , Iowa
This is one tank that the dealer did not top off when we bought it. The low washer fluid warning came on during our 3000 miles maiden voyage. Bought a gallon jug, figuring that we'd have half a gallon to bring home with us. It was took a full gallon to fill it up. That was convenient! Low fluid light was off upon first restart - a 2012 MB chassis.
Titus is offline   Reply With Quote
Old 09-30-2014, 09:43 PM   #7
2005 22' Interstate
I unplugged to the connector and started the engine, indicator was not on any longer (obviously)
I re-connected and it came back on. The reservoir is full it's not a big deal I'll see if it goes out on it's own sometime on the road
Old 09-30-2014, 10:50 PM   #8
TerraYacht's Avatar
2005 30' Land Yacht 30 SL
Castro Valley , California
It sounds like you need the Click and Clack solution: a piece of black electrical tape over the light!
Cliff & Andrea,
2 cats, but they stay home
TerraYacht is offline   Reply With Quote
Old 10-01-2014, 12:14 AM   #9
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, time for a new sensor.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 10-01-2014, 03:50 AM   #10
If you have an OBDII reader that can reset codes, you might try that. Every message that pops up on the dashboard display is accompanied by an OBDII code that can be manually reset.
WBCCI #1105
TAC LA-4
Washer/Dryer jjonesnc Washer/Dryer & Dishwashers 49 04-22-2017 04:11 PM
I need help!!--Univolt, antenna,washer/dryer imeynstein General Repair Forum 27 03-27-2004 11:06 PM
A new AS dish washer model... crazylev The Pet Forum 5 01-04-2004 03:39 PM
Washer / Dryer mldenis Our Community 1 06-19-2003 02:05 PM
