Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Sprinter and B-van Forum
Old 08-06-2016, 10:39 AM   #1
lamato's Avatar
2013 Interstate Coach
Sacramento , California
Window shades/covers
I'm hoping someone has a great solution to our problem. We use those aluminum looking shades for our driver and passenger windows when we're parked for the night. We roll them up and store them during the day. Our problem is that they are not completely staying in the window. Does anyone have a solution? Either a better/different shade altogether or some clever way to keep the shade in the window? Thanks in advance.
Vince and Laura
lamato is offline   Reply With Quote
Old 08-06-2016, 11:20 AM   #2
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
I'm sure there are other ideas coming, but here is ours. Stop by one of the sewing stores and get the 3/4" or 1" square 'hook and loop' (Velcro) stick ons. Put the hooks on the along window frame at the top edge and match the loops on the top edge of the shade. We have smaller windows so three across the top work well. If you put them on the glass/plastic, the sun will cause the glue to release when it gets hot.
Sir Tristan
Air #48582, S/SO #003, WBCCI #4584
SeeMore is offline   Reply With Quote
Old 08-06-2016, 11:31 AM   #3
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
The ones that I use (from Outside Vans) require that you lower the window slightly, and flip 2" long cloth tabs over the edge of the window, and then raise the window to grip the tabs between the window and the frame. They hold very securely.
Old 08-06-2016, 11:38 AM   #4
UKDUDE's Avatar
2014 Interstate Ext. Coach
Sedona , Arizona
Vince and Laura
It looks like you have a 2013 Interstate and those came with some quirky cloth curtains for the cab. So what you have now must have been substituted. I use folding shades from OutsideVan which have a silver reflective surface on one side and help to keep out the heat in the cab area. A little tricky to put up each time but they are very effective.
Old 08-06-2016, 11:57 AM   #5
lamato's Avatar
Yikes. The website for Outside Van says their parts are only available as part of a full van conversion. We don't need that just yet!!
Old 08-06-2016, 12:24 PM   #6
I didn't get mine as part of a full conversion. I got just the window shades by themselves.
But that was about three years ago… Now when I go to Outside Van's "Outside Parts" page where I ordered mine in July 2013, I get a "Page not found" error. Guess they don't sell just the shades anymore.
But adding cloth tabs to whatever shades you're already using might be an answer to your problem, and cheaper, too.
Old 08-06-2016, 01:00 PM   #7
Auburn , Georgia
IMHO those straps are a PITA to hold the curtains in. I added a U shaped plastic clip on the strap that fits over the glass to hold them while you rolled the window up. I made side window (with suction cups) and windshield curtains from Reflectix but have yet to try them out . I think they will be easier to put up and store than the bulky OEM curtains
GETRIDAONE is offline   Reply With Quote
Old 08-06-2016, 01:31 PM   #8
Mjgman's Avatar
Bradenton , Florida
I got a pair of these and they work great..
http://m.ebay.com/itm/112062078636
Mjgman is offline   Reply With Quote
Old 08-06-2016, 02:46 PM   #9
Boxster1971's Avatar
2024 Interstate 19
Fulton , Maryland
I made a set of covers for each window from Reflectix bound on the edges with black bias tape. The windshield cover is held in by the sun visors. All other covers where made slightly over sized so they are sort of wedged in place. I added magnets to the front cab side window covers to hold them in place better.
- - Mike
2013 Interstate Lounge EXT on 2012 Sprinter
- - Mike
2024 Airstream Interstate 19e AWD
Previous: 2013 Airstream Interstate 3500 Ext Lounge
Old 08-07-2016, 02:21 PM   #10
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
I had these.
Sides use suction cups and W/S uses the sun visors to retain it.
2011 Interstate SOLD! Upfitted 2017 Transit 350. SOLD!
Old 08-08-2016, 09:43 AM   #11
lamato's Avatar
- - Mike
Mike, I'm not that talented. Will you please make me a set??? Just kidding, but I know I would mess up anything I tried to do myself!!!
Old 08-13-2016, 04:28 PM   #12
Deecee52's Avatar
2015 Interstate Grand Tour
Granbury , Texas
Our 2015 Grand Tour Ext windshield stock screen is pretty easy to put up, held in place with visors as well as the glove box built into the dashboard. The side window screens are a little more tedious to put up because the straps are not heavy enough to hold the screen in place until the window is rolled up. Also hard to position just right to prevent peeking gaps. I like the magnet idea, and the reflectix idea too, as the heat of Texas would melt the nose cone of a space capsule, and the stock screens just don't seem to block much heat.
Deecee52 is offline   Reply With Quote
Old 08-15-2016, 07:39 AM   #13
Trying to Retire
MILATV's Avatar
Decatur , Illinois
+1 reflex
Added to side windows using Velcro + cutouts for lounge Windows behind shades.
My black van is no longer a sauna when 98 degrees outside now!
Was an oven inside before the reflex addition now seems about same or maybe cooler than outside.
Mike
Mike
If you work until you have everything you 'WANT' - it will probably be too late to enjoy it.
Live in the Moment and enjoy today.
MILATV is offline   Reply With Quote
Vent covers and outside propane covers robwok 1960 - 1964 Overlander 4 02-09-2011 11:56 AM
How do I install vent covers over my vent covers? bigjohn Roof Vents, Skylights & Fans 1 07-29-2010 03:34 PM
Window Shades Craftsman Upholstery, Blinds, Walls & Interior Finishes 4 08-30-2004 07:50 PM
What were the original window covers or shades?? IPM Airstream Motorhome Forums 3 04-07-2004 07:25 PM
Door window rollup shades pittsdriver Upholstery, Blinds, Walls & Interior Finishes 9 08-25-2003 10:32 PM
