Old 01-02-2013, 05:14 AM   #1
2009 22' Interstate
Chetek , Wisconsin
Will not start
Key will not start Mercedes no power to engine. Batteries charged. either a ignition failure or fuse? How do I check? Was -10 now in heated garage.
Key light dash etc. but not turn starter. You can jump starter but will not fire engine?
ON the road
Denny
Wisconsinden is offline   Reply With Quote
Old 01-02-2013, 05:33 AM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
One of those did exactly the same thing at the shop. It turned out the starter had to be replaced.
Old 01-02-2013, 06:53 AM   #3
Gainesville , Florida
At minus ten the diesel fuel may have jelled, then will not start. Try again when the temp warms up. Do you have winter grade fuel in the tank? Jim
Old 01-02-2013, 10:26 AM   #4
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Question
Turn key to on position. All dash lights come on strong??
Turn key to start. No crank, all dash lights go out??
Stupid ?? maybe....key on when starter jumped??, strong crank??
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 01-02-2013, 11:23 AM   #5
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Bad connection at the battery; bad battery. Bad connection at the starter. I would bet it is one of the first two. Clean the battery terminals and cable connections. Make sure they are tight once cleaned.
Old 01-02-2013, 12:40 PM   #6
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Two problems happening here, both related to the cold. #2 Diesel contains parafin, and will gel at low temperatures (below +17F). Winterized diesel is a blend of #2 and #1 diesel, and contains less parafin. Pure #1 diesel won't gel until about -35F.
So, if your temps got down to -10F, good chance that the diesel gelled. Problem is, when the diesel warms back up, the parafin doesn't necessarily dissolve again and blend back into the fuel. It's a relatively complicated process to un-gel your diesel. Check this forum to see what some diesel owners recommend:
Gelled Fuel? What to do? - Dodge Diesel - Diesel Truck Resource Forums
One addition to what Robert Corss wrote: When you turn the key, does the glow plug indicator lamp come on? Does it go off again after a few seconds to a minute or so? Don't try to start the engine until the glow plug light has gone back off, indicating that the cylinder temperature is high enough to support diesel combustion.
Second problem, cold temperatures affect the cold cranking amps of your battery. Cold cranking amps measure the amperage available from the battery at 0F in 30 seconds, from full charge to 50% charge (or 10.5 volts). At -10F, your battery capacity is reduced by about 14%. The upside, the battery should recover as it warms up, as long as you haven't depleted it in the meantime.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 01-02-2013, 02:15 PM   #7
Moflash's Avatar
2007 28' International CCD
Springfield , Missouri
Stand outside of vehicle press door lock on remote wait 30 sec push unlock.Put key in ignition and turn to unlock column shifter pull down to drive then put back into park.Now try to start with foot firmly on brake.
It may have gone into theft mode.Disabling starter and ignition.
If this does not work call M.B roadside assist.They will come to you for free.
Old 01-03-2013, 07:45 AM   #8
2009 22' Interstate
Chetek , Wisconsin
Originally Posted by ROBERT CROSS View Post
Turn key to on position. All dash lights come on strong?? YES
Turn key to start. No crank, all dash lights go out?? YES
Stupid ?? maybe....key on when starter jumped??, YES strong crank?? YES
I tried all these the last message by Moflash is interesting. RV at dealers will be worked on today.
Old 01-03-2013, 01:04 PM   #9
wayneskid's Avatar
2010 22' Interstate
Anchorage , Alaska
Good luck; be sure to let us know the outcome.
- wayne
2010 Interstate 3500 Twin Bed
(2008 Freightliner CRD Sprinter)
AIR #44779
TAC AK-1 !!
wayneskid is offline   Reply With Quote
Old 01-03-2013, 03:41 PM   #10
2009 22' Interstate
Chetek , Wisconsin
No Fix yet
The Sprinter is at dealer in shop...NO fix in sight. Shop is very busy and had little time today so we are on hold.
ANY NEW IDEAS PLEASE SHARE...
Old 01-03-2013, 04:06 PM   #11
Moflash's Avatar
I hope that it is at a Mercedes Benz dealer as it may be to much for a RV dealer and will require special diagnostic equipment
Old 01-03-2013, 04:08 PM   #12
Not a lot of things that haven't been covered so far, that match your symptoms. I'm still mostly convinced it has to do with the fuel system, more so than the electrical system.
Gelled fuel, clogged fuel filter, did we mention the fuel pump? Since yours is a 2009, it's probably not a common-rail fuel injection, and so only has a low-pressure fuel pump, not both low-pressure primary and high-pressure secondary pumps.
It's possible that the electric fuel pump has a blown fuse. Also possible that the fuel pump got clogged or damaged, but the fuse is easier to check, so start with that.
Not likely to be clogged injectors. I very much doubt that enough injectors could all get clogged at once to keep it from starting at all, and unless the fuel filter is damaged, there shouldn't be anything in the fuel line that could clog the injectors.
WBCCI #1105
TAC LA-4
Old 01-04-2013, 08:43 AM   #13
2009 22' Interstate
Chetek , Wisconsin
ok , found bad fuse. replaced fuel filter, two bad glow plugs. Will be on the road at noon today. Life is good, thanks and see you all out there on the road. Thanks for all the support. Denny
Old 01-04-2013, 09:22 AM   #14
Hosanna
PFC
"Tahawus"
RLC
John Prine
Where do I start? slo-an Full-Timing 9 01-08-2012 06:47 AM
2004 LY *Won't Start, No Power* Help RAG General Motorhome Topics 15 12-27-2011 03:41 PM
EU2000i Won't Start PaulR Generators & Solar Power 35 10-10-2011 01:43 AM
Start capacitor for Armstrong 14 A/C pdwhitt Furnaces, Heaters, Fireplaces & Air Conditioning 3 10-04-2011 03:01 PM
High idle, or maybe stuck throttle and hugely loud revving noise at start. PuffinPotter Classic Motorhomes 33 08-08-2011 11:47 AM
