Old 03-18-2015, 02:31 PM   #1
k9jackie's Avatar
2015 Interstate Ext. Coach
Great Falls , Virginia
Where to install a mirror?
I like the roadtrek door mirror and was wondering if anyone has attempted a mirror installation on the door panel. The tiny bath mirror aint cutting it for me
ID:	234479   Click image for larger version
2014.5 Airstream Interstate Ext.
k9jackie is offline   Reply With Quote
Old 03-18-2015, 03:36 PM   #2
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Consider this: Mount it on the cabinet door behind the bathroom, not on the bathroom extension panel. That way you can open the cabinet door and use the mirror more easily from the aisle, at whatever distance works best for you.
And you could choose to mount the mirror on the outside of the door or on the inside, whichever you prefer. Or even both inside and out, so two people could use mirrors at once, one standing in the aisle to the front of the open cabinet door and one to the back.
The mirror couldn't be any taller than the door it's mounted on, of course, so the mirror on the cabinet door would be smaller than one on the bathroom extension panel. But a big mirror would be wasted on the bathroom extension anyway because you couldn't step far enough away from it to take advantage of the extra length.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 03-18-2015, 03:43 PM   #3
Related thought:
If you add a tempered glass mirror to any hinged panel, put some more screws into the hinge to help support the extra weight. A pane of silvered glass is surprisingly heavy.
You could get lighter-weight materials for the mirror, but usually with more distortion in the mirror image.
WBCCI #1105
TAC LA-4
Old 03-19-2015, 08:41 AM   #4
They deleted this in newer Interstates? Our 2007 came with a long mirror on the inside of the closet door. I have worried that mounting another one on an exposed surface might lead to unforeseen and undesirable reflection effects. I have metallic trim here and there on the inside of my minivan, and even that little bit manages to catch the full force of the sun and throw it where I don't want it.
Old 03-19-2015, 08:51 AM   #5
Lily&Me's Avatar
Normal , Illinois
Ours has a long mirror, too, but I put a small one up on the inside of the bathroom door, for hair brushing and make-up.
You can find small ones for lockers in back to school areas of WalMart, etc.
Double stick tape, and you're good to go.
Maggie
Old 03-28-2015, 12:15 PM   #6
Jeff
jkinglet's Avatar
2013 Interstate Coach
Seattle , Washington
Images: 37
Indestructible suction cup mirror on outside of bath door window. Works great. Amazon!
jkinglet is offline   Reply With Quote
Mirror, mirror off the wall! Pudentane General Repair Forum 2 08-09-2009 08:28 PM
Mirror Mirror on the wall early General Interior Topics 2 11-20-2005 10:13 PM
Mirror Mirror on the wall.... 05ModPod The Pet Forum 9 03-15-2004 09:42 AM
Bathroom Mirror niftypkg General Interior Topics 4 09-03-2002 06:38 PM
