Old 10-18-2019, 04:47 PM   #1
jonmarinello's Avatar
Santa Barbara , California
Question Where is the propane tank on a 2010 Interstate?
I need to change the Manchester Tank G12846 LP Gas Tank - Remote 90 OHM Sender which I am told is the correct model sender. I've crawled under the rear of the coach and don't see it.
jonmarinello is offline   Reply With Quote
Old 10-19-2019, 03:52 PM   #2
Think I found where it is
Looks like it might be under the passenger side twin bed at the forward end. My interstate has the Airstream fulltime bed conversion so I need to pull up some wood plates to check for sure.
Old 10-19-2019, 04:58 PM   #3
Contributing Member
Pahaska's Avatar
Austin (Hays County) , Texas
Simply start at the fill port and follow the propane lines from there to the tank. I think you will find it forward of midships in the center of the coach.
John W. Irwin
2018 Interstate GT, "Sabre-Dog V"
WBCCI #9632
Old 10-19-2019, 09:07 PM   #4
Thanks for getting back to me.
That's how I started but the lines go up and into the coach but below where you can see them in the coach. Tomorrow I will remove some of the fulltime bed wood panels and continue to follow them. Prior to that I will crawl under the coach and see if it is in fact forward of midships under the coach.
Old 10-19-2019, 09:18 PM   #5
2013 Interstate Coach
Raymond , Iowa
Try following back from the generator. That hose should be entirely underneath the chassis.
Titus is offline   Reply With Quote
Old 10-19-2019, 10:40 PM   #6
Contributing Member
Pahaska's Avatar
The safety codes require that, except for individual feed lines for the stove, furnace, and water heater, all lines must be outside of the coach. I think what you are seeing is a tap entering the coach to something like the stove. This applies to trailers and vans.
Airstream would never have disregarded the safety codes.
John W. Irwin
WBCCI #9632
Stuck propane valve on full propane tank. BoatNutG2 Airstream Lifestyle 3 09-15-2019 10:22 PM
Airstream Excella Propane Tank Cover (two tank) Rockifish Airstream Classifieds 0 05-27-2019 03:08 PM
Black Tank, Grey Tank, New Tank, Old Tank Bunkroom Waste Systems, Tanks & Totes 3 07-22-2014 09:35 PM
2010 BMW MOA International Rally Redmond, Oregon July 15 18, 2010 tikitraveler Other Rallies & Events 1 05-31-2010 08:07 PM
2010 Suburban 2500 or 2010 Toyota Sequoia 5.7 laynlow Tow Vehicles 37 03-15-2010 10:48 PM
