Old 07-24-2016, 06:58 PM   #43
lewster's Avatar
Naples, FL , Hood River, OR
When was the 50 watt solar panel upgraded to 100 W
Originally Posted by Marks71 View Post
I'm a bit confused by the 3 posts from Lewster, Shark, and McRider, including Lewster referencing 30amps.
Anyway, Attached is a pic of my monitor. I might be misinterpreting the monitor, or it could be calibrated incorrectly. This is a 200w system (rigid panels) with 10g wiring, and a MPPT charger/controller. I don't really know solar, I'm just reading back the specs of a system someone else installed for me.
The reason I'm interested in this is whether to try to fit another panel (i.e. 300w total).
thanks for any input.
(btw ... how you folks insert an image as opposed to attaching?)
Your meter is displaying VOLTS, which are probably the output from your solar panels. It will not display the amps it is sending to the batteries unless you have a shunt installed on your negative battery cable ( positive for you budding Victron users).
Big difference!!
Old 07-25-2016, 04:11 AM   #44
2015 Interstate Ext. Coach
Chicago , Illinois
You're right!!
Marks71 is offline   Reply With Quote
With a 160 Watt 12V battery charger solar panel… Do I really need… beachbouy Generators & Solar Power 6 05-02-2016 06:31 PM
Renogy 100 watt suitcase AWCHIEF Generators & Solar Power 24 02-07-2016 08:25 AM
Upgraded solar controller lsbrodsky Generators & Solar Power 1 11-21-2013 11:18 AM
Advice on 15 Watt solar battery charger rywnc Generators & Solar Power 2 05-03-2010 08:09 AM
