Originally Posted by K9CarCrate
I'm wondering if the tire pressure labels on the Sprinter are based on when the chassis-only is delivered to Airstream factory prior to adding all the Airstream coach stuff. I've been interested in this subject, but have never gotten a straight answer. All I know from my personal driving experience is that 61psi wears the tires down and unevenly. I run them higher and slightly vary the psi based on current temperature, season, and driving conditions I will encounter with my driving plan for the day. The base PSI I work off of is 75psi. I'm over 70K in highway miles on my 2014 AI.
Lotus 54 has some very interesting photos of vehicle tire placards - and they contradict what I think the way the system works:
Both the chassis manufacturer and the completed vehicle manufacturer (in this case Mercedes and Airstream, respectively) are required by law to provide a vehicle tire placard - the finishing manufacturer (Airstream) having the over-riding placard.
The chassis manufacturer sets the GAWR's (Gross Axle Weight Ratings) based on what they designed the vehicle to do. Tire size/ pressure are then set based on that.
So, in theory, a bare chassis shouldn't be different than a completed vehicle as the GAWR's should be the same - except, perhaps, for situations where the completed vehicle's tire pressures are adjusted for handling purposes - and that appears to be the case in Lotus54's photos - the GAWR's do not line up with the inflation pressure.
