Old 08-24-2015, 06:34 AM   #1
2014 27' Flying Cloud
Seguin , Texas
What black tank treatment do you use in your AI
Inquiring minds and all......
Laidback1 is offline   Reply With Quote
Old 08-24-2015, 06:51 AM   #2
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
I usually use an environmental friendly (no formaldehyde) additive that breaks down waste bacterially. Lots of those products out there, just read the labels. They tend to not mask the odors as well as the formaldehyde brands, but are safe for the campground systems and can help dissolve the solids in the tank which means less chance of clogs. In hot weather, I usually add an additional treatment as the tank hits the halfway point. That helps with the odor.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 08-24-2015, 06:54 AM   #3
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
In addition to the above, we will put some Dawn dish-washing liquid in the tank with a few gallons of water before moving to a new site. The liquid soap and sloshing around on the road helps to keep the inside of the tank "clean" or at least cleaner than it would otherwise be.
Bob Martel
WBCCI# 5766
Old 08-24-2015, 07:39 AM   #4
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Enzyme treatments, no particular brand. With a macerator pump, any treatment that helps break down solids helps the pump work more efficiently.
Also, just before I dump the tank, if it's not already full I add hot water until it is full. Hot water helps soften the solids. Since an Interstate has a wet bath, it's really easy to use the shower head to add the hot water to the black tank by running the shower into the toilet.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 08-24-2015, 08:16 AM   #5
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Clorox removes all odor and then evaporates....
Not standard practice I know, but it is cheap and it works for me.
Old 08-24-2015, 09:15 AM   #6
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
I use the geo method.
Liquid water softener like Calgon and store brand liquid laundry detergent.
Lance
Top is offline   Reply With Quote
Old 08-24-2015, 09:23 AM   #7
2015 16' Sport
Portland , Oregon
I thought bleach was a no-no because it kills the bacteria that make septic systems work (ie at the dump station)
leedav is offline   Reply With Quote
Old 08-24-2015, 09:39 AM   #8
Tuco's Avatar
1988 32' Excella
Ojai , California
Since we full time in our trailer I just flush the tank with water using a "Flush King" adapter on the outlet pipe once a week (or when I smell it).
Dave & MJ
1988 32' Excella 1000 (Beauty)
1999 White Dodge SLT Laramie 3500 Dually, 4x4, 5spd, 5.9 CTD 260k+ (The Beast)
Tuco is offline   Reply With Quote
Old 08-24-2015, 09:57 AM   #9
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
It does kill the bacteria, but the was I see it holding tanks are not septic tanks, so killing the bacteria and odor is ok.
The chlorine will evaporate reasonably quickly once it has done its job, and the tanks are emptied causing very little if any environmental impact.
And remember, bleach is commonly used in washing machines that dump into sewers and septic systems.
I think it is a much better alternative to commercially available RV treatments that contain phemaldehyde.
And it makes the trailer smell fresh.... I find the common "rv smell" kinda repugnant, whether the smell is phemaldehyde, waste, or a waste and phemaldehyde mix.
Old 08-24-2015, 02:40 PM   #10
richw46's Avatar
Lexington , Kentucky
I used Happy Camper's Extreme holding tank treatment. It's a powder, it doesn't say what's in it. It's designed for 30-40 gallon holding tanks, ours is 18. It says to mix and pour into the tank, adding enough hot water to bring it to half a tank. I figured that would be 15 gallons so I got our tank about 3/4 full. I left it in there for 12 hours, then drove 500 miles. I dumped when we arrived. The odor that had been there previously was gone. We also had some kind of odor absorber by the vanity. Between the two things, life is better
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is offline   Reply With Quote
Old 08-24-2015, 03:43 PM   #11
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Ditto the GEO method. I have been experimenting with it during this long hot summer. It works. Smell free and seems to help keeping the tanks cleaner dumping and rinsing. One cup bleach, one cap liquid Calgon and one cup dish soap mixed with two liters of water added to the black tank and same mixture to gray tank.
Http://thegeomethod.blogspot.com/
https://sites.google.com/site/cbruni/
MICHAEL
Old 08-24-2015, 05:40 PM   #12
hshovic's Avatar
2007 25' Safari FB SE
Bozeman , Montana
Images: 20
I use the "wife irritation" method. I wait until 1/2 full, drive around the campsite, or take a day trip, then dump immediately upon stopping. Never let it sit longer than a few minutes before dumping. Never let waste sit in there longer than a week. Every time (for 70,000 miles) I notice the tank is totally clean upon looking into the toilet. No using chemicals, no rinsing tank, no hose down the toilet. "Irritation"? Oh, because I let the whole campground know how wonderful it is going. I call out "waste management!" before I review the process to anyone who will listen.
Hank
WBCCI 1489 AIR 20708
2015 Chevy 3/4 ton 4 x 4 gas; 2007 Safari FB SE
"Its better to light just one candle than to curse the darkness,
Unless you're blinded by the light..."
hshovic is offline   Reply With Quote
Old 08-24-2015, 09:23 PM   #13
Seguin , Texas
Folks,
Thanks for sharing! I'm going to try an enzyme based to see how that works out. Will give status as I learn more about it....
Old 08-24-2015, 09:38 PM   #14
2005 22' Interstate
Pittsburgh , Pennsylvania
Do you have some problem you are trying to solve? I have never found a need to do anything. If you have an odor problem, it is very likely a plumbing issue.
Formerly: 2005 Airstream Interstate (2500 T1N)
Now: 2014 Great West Vans Legend SE (3500 NCV3)
avanti is offline   Reply With Quote
Holding tank treatment moore41 Waste Systems, Tanks & Totes 3 02-01-2015 07:16 AM
How you guys treat your 16's Grey/Black combined tank? shockfly 2005 and newer - Bambi all models 1 10-22-2014 11:42 AM
Black Tank, Grey Tank, New Tank, Old Tank Bunkroom Waste Systems, Tanks & Totes 3 07-22-2014 08:35 PM
The effect of using the blue liquid black water treatment on septic fields wacnstac Waste Systems, Tanks & Totes 6 06-01-2006 09:21 PM
Water treatment ideas Xray Fresh Water Systems 21 08-22-2005 09:13 PM
