Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Sprinter and B-van Forum
Old 09-03-2006, 08:10 AM   #1
Profile:  Brooklyn , New York
Westfalia skylight rain sensor
I just bought a 2005 Westfalia. and I love it. I have one problem, though. The rain sensor on the skylight is so sensitive to humidity that it closes automatically even when it is not raining. That's the time I need the fresh air the most. Does anyone have any suggestions - perhaps a manual override on the controls - or any other fix that would make the skylight more practical in oue east coast humid summer weather? Or do I have to look into replacing the skylight with a manually operated one?
Thank you for any and all suggestions!
mbbrown55 is offline   Reply With Quote
Old 09-03-2006, 09:11 AM   #2
wbrownrr's Avatar
Profile:  2002 22' International CCD
San Luis Obispo , California
If it's a Fantastic Fan I suggest calling the factory. I called with some questions on mine and they were VERY VERY helpful. They may have a simple suggestion to correct the problem. I don't remember if I got their phone number from the manual that came with the AS or from the web... shouldn't be hard to get the number either way. Call them.. you'll be glad you did.
Wayne
2002 22' CCD
1997 Dodge Ram 1500 5.9L
wbrownrr is offline   Reply With Quote
Old 09-23-2006, 05:41 AM   #3
Thanks, Wayne. It turns out that it is not a Fantastic Fan. From what you described, I wish it were! The dealer told me that it has a broken rain sensor that needs to be replaced, so I am going to do that soon.
Marechal
Old 05-30-2007, 02:16 AM   #4
Profile:  Huntington Beach , California
How is that newly replaced sensor?
Just bought westy and it was closing automatically without rain.
songjc is offline   Reply With Quote
Old 05-30-2007, 06:52 AM   #5
yukionna's Avatar
Profile:  Massachusetts
Images: 18
Send a message via Yahoo to yukionna
Unfortunately, in the case of high humidity or condensation, the sensor will think it is raining and will close. and open. and close. and open all night long.
We get around this by manually overriding the system and hand cranking the skylight open.
WBCCI Region One
Attitude is the only difference between ordeal and adventure.
yukionna is offline   Reply With Quote
Old 02-03-2008, 05:06 PM   #6
Manually override skylight
How can you manually override the skylight motor and rain sensor? I'd like to set up my unit to be able to do that.
Thanks!
Old 02-03-2008, 08:49 PM   #7
yukionna's Avatar
Images: 18
Thanks!
First pull gently down on the black knob. This will disengage the gear from the gears that are run by the auto sensor. Then turn the black knob to open the cover. That's it.
WBCCI Region One
Old 02-08-2008, 05:42 PM   #8
Thanks so much for responding!
Where exactly is the black knob you are talking about? I have pulled off the frame around the skylight, and found a black plastic T-shaped hexagonal driver that doesn't seem to fit on the vertical rod I thought I was supposed to turn to close the skylight. If you can describe its location, I (hopefully) will be on my way to solving this mystery.
Old 02-08-2008, 08:02 PM   #9
yukionna's Avatar
Images: 18
The black know is external to the inside of the frame. You actually would have had to remove the black knob before you could remove the frame around the skylight.
You must have a different set up than I have. Post a picture if you can.
WBCCI Region One
Old 02-09-2008, 05:39 AM   #10
Thanks, I will.
I do have the black knob as a separate piece. The problem is that when I try to turn the bolt with it, it just spins without engaging the bolt. I am wondering if I have to somehow disengage the bolt from the motor to free it up so it will turn. Otherwise, the black knob doesn't seem to be the right size.
We have tried metric sockets too, and the bolt seems to be in between 6 & 7 mm. Neither one fits properly.
Old 02-09-2008, 08:34 AM   #11
Here's a picture of the bolt.
Let me know if the attachment can be seen. I haven't tried to attach a file before.
Old 02-09-2008, 12:09 PM   #12
Fyrzowt's Avatar
Profile:  2000 25' Safari
Templeton , California
Images: 8
I appears that Yukionna was refering to a Fantastic fan, If I understand correctly, yours is another brand.
You may be able to put in a switch to overide the sensor/take it out of the equation??
The Fantastic fan on my last trailer would also close in the coastal fog. Seems to be a normal function of the sensor.
Dave
Fyrzowt is offline   Reply With Quote
Old 02-09-2008, 01:18 PM   #13
The problem is that my sensor worked long enough to open the window, and quit. Now it is stuck open, and I am planning a 3,000 mile trip, starting next Thursday!
At the least, I need to get it closed for hte trip, and, ideally, have a way to open it manually, as we will be driving to southern Florida, and we are looking forward to some fresh air...
Old 02-11-2008, 04:30 AM   #14
We did finally manage to close the skylight. My husband fashioned a socket that fit the bolt, and closed it carefully with a drill.
2003 International AS Pahaska 2003 International 147 05-28-2004 10:48 AM
Skylight part question ColtSAA45 Roof Vents, Skylights & Fans 3 04-22-2004 09:05 PM
Monsoon, act II Pahaska Our Community 11 10-25-2002 08:34 AM
Vulken and Polish or Polish then Vulkem? rookie Cleaning, Stripping & Polishing 5 07-23-2002 08:15 AM
Skylight - WARNING - possible Problem apple 1 Roof Vents, Skylights & Fans 0 03-24-2002 10:16 AM
