Old 08-08-2016, 05:12 PM   #15
Wolf Alaska's Avatar
Madison , Alabama
My Onan 2800 Microlight developed a failure to run condition although it would turn over (crank). I tried several things, but since I doubted the plug was firing took it to certified Onan shop. Testing proved no ignition. Disassembly req'd. There is an ignitor module behind the flywheel/timing wheel that is pulled to get to the ignitor module. Replaced that module & its been running good for 10 years & 400 hours.
You may want to find an Onan shop for this one. I was treated very well & they cut me some breaks on the hours charged because it was such a job. The module was only $80.
Let's Roll. !
Wolf
Wolf Alaska
M.S./CFI/IR/ME/CP
FMCA SKP GS GPAA NRA USN (Ret)
Wolf Alaska is offline   Reply With Quote
Old 08-08-2016, 05:16 PM   #16
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
If the welder placed the ground clamp near the work, the chances of welding the muffler on causing electronic damage is very near nil.
Gradiens super tenui glacie.
Generator muffler install 73shark Sprinter and B-van Forum 7 06-05-2015 06:35 PM
Generator Backfire, Goodbye Muffler ! alumascoupe Generators & Solar Power 7 01-18-2013 03:22 PM
furnace wont start matthew NYC Furnaces, Heaters, Fireplaces & Air Conditioning 5 02-15-2009 05:11 PM
Brake light wont work; where to start. Swat Brakes & Brake Controllers 2 07-11-2007 08:09 PM
Generator box (sound muffler) BamCamper Generators & Solar Power 9 06-13-2007 11:55 AM
