Old 09-21-2013, 09:18 AM   #1
Trying to Retire
MILATV's Avatar
Decatur , Illinois
While emptying my thanks at Topsail Hill RV park in Florida I noticed a little black box connected by two wires dangling just below the Mercator pump.
Further investigation showed there were two just like it still stuck to the fresh water tank. So I assume (cuz I don't have AS schematics) that this is the water tank level sensor of some kind. I had some silicone in the van, but it was buried under everything, and we were pulling out to head to Ft Wilderness. So I zip tied it up and left it to be repaired at home after the trip (14 days) Upon pulling in the drive I noticed it hanging again, I'm pretty good with a zip tie, so this seemed odd, but nope - a 2nd sensor had fallen off the tank! So: 5,000 miles on the van, and yes - some 96 degree days in the sun - but doesn't seem like things should be falling apart. 3 hours to an AS dealer, now I'm not sure position of sensor (top, middle, bottom)
QUESTION: - am I correct that these are water level sensors? - what is best way to reattach so they won't fill off again - are there other - this is going to happen sooner or later issues that a few zip ties and goop can prevent now?
BTW: shredded my trailer plug connector on the driveways during my trip, (couple of times) why the heck would the low point on my bumper be the trailer plug instead of the skid plates????? Do these designers ever drive these vans?
ID:	196071   Click image for larger version
Mike
If you work until you have everything you 'WANT' - it will probably be too late to enjoy it.
Live in the Moment and enjoy today.
MILATV is offline   Reply With Quote
Old 09-21-2013, 10:06 AM   #2
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
You are correct that they're tank sensors. Should be four in all, per tank, located one above the other, more-or-less equally spaced since the tank is rectangular. There may be some adhesive residue on the tank to show where they were stuck on before.
Never had one fall off, so I'm not sure what the best way would be to stick them back on.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 09-21-2013, 11:41 AM   #3
David M's Avatar
2013 Interstate Coach
Orange County , California
My sensors haven't fallen off yet either, but I did shred my trailer plug connector. My dealer is going to stock up on some steel wheels for the hitch so I will have them installed where the current skids are -- hopefully a tad lower so the plug isn't the low point. I'll post some pics unless you do yours first.
David
David M is offline   Reply With Quote
Old 09-21-2013, 11:53 AM   #4
Trying to Retire
MILATV's Avatar
Decatur , Illinois
Originally Posted by David M View Post
My sensors haven't fallen off yet either, but I did shred my trailer plug connector. My dealer is going to stock up on some steel wheels for the hitch so I will have them installed where the current skids are -- hopefully a tad lower so the plug isn't the low point. I'll post some pics unless you do yours first. David
Here it is after I bolted it back on, the cover was toast ( picked up in the driveway) there has to be a better place for this.
Mike
Old 09-21-2013, 02:48 PM   #5
kaylorsan's Avatar
Los Gatos , California
Hmmm. The position of the trailer plug is interesting. Mine is up higher. I had to move it to the left to get access to put is locking hitch pin. I'll try to snap a picture when we pull over.
I'm interested in the skid 'wheels' you mention. I've been considering adding something like that. My current skids bars were once round, but are now some mangled geometry. I guess that's the price you pay for extra storage (EXT model)
kaylorsan is offline   Reply With Quote
Old 09-21-2013, 03:06 PM   #6
Trying to Retire
MILATV's Avatar
Decatur , Illinois
Yep, I backed out of my daughter's driveway and left a nice little mark in the street (will remind her every day that I came to visit).
My wife heard it dragging bad and said I should stop - I said, "na It's ok, just the skid bars dragging". Then I saw the trailer lights plug cap setting in the road. WHOOPS!
On the bright side - gear, food and bedding for 14 day trip all fit in the van, thanks to the extra room in the EXT.
Mike
Old 09-21-2013, 03:47 PM   #7
UKDUDE's Avatar
2014 Interstate Ext. Coach
Sedona , Arizona
Yep - I had one of my tank sensors fall off too. This is one of countless issues I've had with my 4-month old Interstate EXT. Assembly quality is dreadful.
Old 09-21-2013, 04:14 PM   #8
Newbie
joemikeb's Avatar
Fort Worth , Texas
One of my water tank sensors fell off too. Airstream insisted on replacing all the tank sensors and sent the dealer a set of VERY detailed instructions on preparing the tank surface, applying the adhesive, etc. Airstream covered the repairs under warranty so, no complaint there.
It is curious to me, and I hope Airstream has taken notice of the fact that all these are water tank sensors and maybe that was the reason for what the mechanic described as, "…unusually detailed instructions"?
Make errors otherwise the Great Spirit realizes
you have finished your purpose on earth.
Navajo saying
joemikeb is offline   Reply With Quote
Old 09-21-2013, 04:59 PM   #9
kaylorsan's Avatar
Hmmm. The position of the trailer plug is interesting. Mine is up higher. I had to move it to the left to get access to put is locking hitch pin. I'll try to snap a picture when we pull over. ..
Here you go. My connector on the 2012 model seems to be in a better position. I'm not sure why they made that change for your model year.
Old 09-21-2013, 06:14 PM   #10
Boxster1971's Avatar
Fulton , Maryland
I think they made the changes because the 2013-2014 Interstates have a new removable hitch cover over the entire hitch for a clean bumper look.
- - Mike
Boxster1971 is online now   Reply With Quote
Old 09-21-2013, 07:27 PM   #11
Fulton , Maryland
Hitch cover photos
Here are a couple of photos of the new hitch cover on 2013 & 2014 Interstates from the Airstream web site. This is causing the trailer plug to be below the hitch skids. I've scraped my EXT Lounge many times and added some wood blocks to the skids to minimize the damage. I also raised my trailer plug by 1/4" by cutting and re-welding the bracket. Bit it only raised the plug to same level as hitch bumpers. I would welcome some sort of steel wheels on this hitch like many of the long overhang class C's I've seen.
Name:	Interstate Removable Hitch Cover.jpg
ID:	196136   Click image for larger version
Name:	Interstate Streamlined Hitch Cover.jpg
- - Mike
