Old 10-19-2013, 03:26 PM   #1
BikerBill
2014 Interstate Ext. Coach
Poconos of Pa , Pennsylvania
water tank inlet lock
On our new 2014/14 Interstate motorhome I'm quite concerned about the screw off chrome metal cap for the manual water tank fill. I've heard rumors that some have accidentally had diesel added and I'm also concerned about pranksters opening it and dumping something into our water supply. Has anyone had any luck finding a locking screw-type cap to replace the current cap?
Bikerbill is offline   Reply With Quote
Old 10-20-2013, 09:00 AM   #2
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
Welcome to the forum. Have you tried RV suppliers such as camping world?
Old 10-21-2013, 09:40 AM   #3
2012 Interstate Coach
norman , Oklahoma
I have the same concern but have never seen anything. Good luck in your search and let us know if you turn something up!
russ240 is offline   Reply With Quote
Old 10-21-2013, 07:32 PM   #4
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
Perko Vented Tank Filler and Lock
I also would like to have a lock on this water fill. So I took a close look at my water gravity fill cap and determined the item is made by Perko with Fig. 540 on it as a part number. Then through the magic of Google I found the Perko web site and this is actually a Boating/Marine item used for both fuel and water vented fillers. The following links will take you to the details.
Perko Web site for Fig. 540
http://www.perko.com/catalog/category/fills_and_vents/product/57/ [Click on the Ordering tab to see part number for water filler]
Perko Web site for vented filler lock:
http://www.perko.com/catalog/category/fills_and_vents/product/207/
Iíve attached a copy of the instructions for the lock so you can see how it works.
They are available on Amazon and eBay, plus lots of other marine suppliers. This is not a normal RV item.
Enjoy,
- - Mike
Old 10-21-2013, 08:28 PM   #5
PSchw's Avatar
2005 39' Skydeck 390 SD
Livingston , Texas
Thanks Mike just ordered it from Amazon.
Peter
PSchw is offline   Reply With Quote
Old 10-21-2013, 09:28 PM   #6
David M's Avatar
Orange County , California
Me too. Thanks Boxter1971! I hope I ordered the right part. i only ordered the locking fill insert, p/n 0525DP0BLK.
David
David M is offline   Reply With Quote
Old 10-22-2013, 06:22 AM   #7
norman , Oklahoma
Love this forum. Thanks Mike!
Old 10-22-2013, 06:45 AM   #8
BikerBill
love the forum
OK, I got my answer and thanks. Will order it soon.
Old 10-23-2013, 06:55 PM   #9
Fulton , Maryland
Mine came for eBay supplier Northern Marine Discount today; p/n 0525DP0BLK. It goes into the filler fairly easy but I found it a bit tricky to remove.
- - Mike
Old 10-24-2013, 03:04 PM   #10
PSchw's Avatar
Livingston , Texas
Got mine today too. Tried it out right away got in OK as I turned and try to pull it out the key with the lock came out but not the insert. Could get the insert out with a needle nose plier but I assume this should be not normal operating procedure.
I guess quality could improve a little now I waiting for a response from PERKO for replacement. Hope the next one works better.
You may want to makes sure you have a needle nose plier in your rig.
Peter
Old 10-24-2013, 06:58 PM   #11
Fulton , Maryland
I found it took both hands to remove the lock. I used one finger to hold the lock body from turning while I tuned the key to release the lock and pull it out of filler. I didn't need tools just a little finesse.
- - Mike
Old 10-24-2013, 07:20 PM   #12
PSchw's Avatar
Livingston , Texas
Did not pull hard just tried turning the key and pulling the locking cylinder came out then you have no choice then using a needle nose plier. I assume it is a manufacturing defect so much for Made in the USA.
Hope my second one will be OK still I will keep a needle nose plier in the rig.
Peter
ID:	198680   Click image for larger version
Old 10-25-2013, 08:59 PM   #13
Fulton , Maryland
Peter
Ouch! That doesn't look good.
- - Mike
Old 10-26-2013, 04:58 PM   #14
David M's Avatar
Just got mine today, and the tumbler mechanism came out of mine too while trying to remove the insert. I too had to use needle nose pliers to get the insert out. I'm not sure if I'm going to keep this because I don't want to be in a situation where I can't fill my fresh water tank. Very disappointed
David
