Old 06-12-2016, 10:47 PM   #15
2016 Interstate Lounge Ext
newport beach , California
Thank you all! The propane switch answer was the key! Plenty of hot water and propane for the trip. One other question...does the rear A/C only operate when Generator is on or hooked up to Shore Power? It won't work on House Battery or Inverter?
hpnewport is offline   Reply With Quote
Old 06-12-2016, 11:05 PM   #16
Bellevue , Washington
Works on generator and shore power. There is an automatic switch that routes power from either/or to the AC. Won't run on battery/inverter because the battery and inverter are both too small to handle it.
amirm is offline   Reply With Quote
Newbie FW system question TheHandyDan Fresh Water Systems 6 09-09-2015 12:43 PM
Newbie Needs Help for Water System Pump weaver1950 Fresh Water Systems 2 08-13-2013 05:20 PM
newbie question - propane system JohnGough On The Road... 10 05-29-2013 05:04 AM
Newbie Questions -- Bambi Water System -- any help is appreciated! dwy7 1964 Bambi II 1 02-10-2009 10:55 AM
