Old 12-10-2019, 04:25 PM   #1
Mound House , Nevada
Water pump strainer basket
I have a 2016 Grand Tour with the water pump located under the huge and useless freezer. How in the heck do you get in there to remove and clean the starsiner basket? I have tried and tried as instructed by the manual to squeeze those little tabs and lift it out to no avail. There just isn't enough room to work in. Has anyone succeeded in its removal, cleaning and reinstalling?
l0velydesign is offline   Reply With Quote
Old 12-10-2019, 07:56 PM   #2
swilly43's Avatar
escondido , California
Access Panel
On mine, there is an access panel that can be pulled off. The panel has two latches similar to the drawers. Just pull on it in a straight pull. The strainer screen is easily accessible. Just pull it out from the top and clean it. Intall, and test for leaks.
swilly43 is offline   Reply With Quote
Old 12-10-2019, 09:05 PM   #3
2012 Avenue Coach
Corpus Christi , Texas
I don't know if yours is the same brand, but here are some pics from the forum that helped me. I wish I could recall who to credit.
Name:	Airstream Water Pump Filter removal.jpg
ID:	357530   Click image for larger version
Name:	Airstream Water Pump Filter debris.jpg
Name:	Airstream Water Pump Filter clean.jpg
rowiebowie is offline   Reply With Quote
Old 12-11-2019, 10:58 AM   #4
Thanks for the pics. I may have to detach it at the blue pull to get at the screen release area. I guess I have fat hands and can't get in there. This van with all of it's bells and whistles has been a long learning curve for me but I'm slowly getting it.
Source for galley sink strainer basket Schmitte Sprinter and B-van Forum 5 11-26-2019 02:46 PM
Pump Strainer Loose? Al and Missy Fresh Water Systems 0 11-12-2019 03:26 PM
Water pump strainer cleaning Tnsimons Sprinter and B-van Forum 12 05-13-2019 10:48 AM
Water pump strainer cup Cispook Water Heaters, Filters & Pumps 1 11-04-2017 02:27 PM
City water inlet strainer? Zybane Fresh Water Systems 9 02-18-2017 09:39 PM
