03-07-2019, 11:27 AM
2017 Interstate Grand Tour Ext
Gulf Breeze
Water pump problem
I may have a water pump problem. A few weeks ago I cleaned the small water filter that is attached to the pump and now the pump will free run after several days of no use. I'm glad I cleaned the filter as it was gunked up as others have noted. I've re-seated it twice but I still have the problem. I don't normally keep the pump on all the time but lately I have to try and isolate the problem. It can take up to week before the problem arises. I have checked everywhere for water leaks but I have found none. Does not mean I don't have a water leak it just means I have not found one. Is it possible to lose pressure and not have a water leak? Is there a simple way to check for a leak in the plumbing system? Thanks
03-07-2019, 01:13 PM
Sneedville
, Tennessee
Do you get water pressure build up when you are connected to city water? How much water is in your fresh water tank?
03-07-2019, 01:39 PM
2007 22' International CCD
Corona
There should be a rubber O-ring on that filter (actually a 'pump strainer') that seals it to the housing. Check to see that it is still there. Very easy to lose and, according to Murphy's Law, will roll when it is dropped to the hardest place to recover it from...
03-07-2019, 02:13 PM
Gulf Breeze
No problems that I am aware but it would take seveal days to confirm. We have a trip scheduled soon so I will be able to check this out more closely. My tank is about 1/3 full according to the "Inaccu-Gauge" which I read as I have water in it and its less than full.
03-07-2019, 04:25 PM
Gulf Breeze
Yes, pump strainer. Not sure why I called it a filter. Hope to check that O-ring tomorrow. Thanks for the tip.
03-08-2019, 11:06 AM
League City
Originally Posted by orlik
... now the pump will free run after several days of no use. ... It can take up to week before the problem arises. I have checked everywhere for water leaks but I have found none. ...Is it possible to lose pressure and not have a water leak? Is there a simple way to check for a leak in the plumbing system? Thanks
By "free run", do you mean that the pump will come on by itself?
And if so, how often does it occur and for what kind of duration?
03-08-2019, 01:27 PM
Gulf Breeze
When we were on our last trip (end of January) and driving home my wife heard the pump running. I turned it off. There were no facets on since we were driving and all fixtures turned off. When we got home I was able to build pump pressure and the pump stopped running. I decided to leave the pump switch on so I could try and figure out what was happening, checking the RV everyday. Several days passed and everything was fine. Then I checked again one day and when I walked in the RV the pump was running again . It could have been running all night. That's what I mean by free running, maybe its the wrong term. Turned on the faucets and I was able to build pressure again and the pump turned off. This has happened about 3 times in the past 6 weeks.
My wife just reminded me this happened once before shortly after we got our AI in 2017. We were driving and my wife heard the pump running. Turned it off. Once back at the camp site we built pressure back up and everything was ok and we never had the problem again until just recently. Very odd. That is why I was asking if there is a clever easy way to check for air leaks. I say air leak only because I have not found any water leaking - at least not yet.
Per rmkrum suggestion I checked the O-rings and they appear fine.
03-08-2019, 01:33 PM
2013 20' Flying Cloud
Westerly
, Rhode Island
Most of the time if there is no leak it is a problem with the check valve inside the pump letting water go backward through the pump which decreases pressure in the system and causes the pump to turn on occasionally. Lots of people replace the whole pump, but for an hour or so of work you can just replace the check valve for less than $15.
03-08-2019, 04:20 PM
Gulf Breeze
smithcreek, thank you for your suggestion. When you say "turn on occasionally" do you mean it turns on and off, or does it turn on and stay on? My pump is staying on until I turn it off.
03-08-2019, 04:52 PM
Westerly
, Rhode Island
No, it would just come on for a few seconds until the pressure built back up in the system. Sounds more like a problem with the pressure sensor in the pump.
03-08-2019, 05:02 PM
Sneedville
, Tennessee
What brand pump is used? I have a spare I can send you to swap in and see if it is the pump.
03-08-2019, 06:55 PM
2017 25' International
Carlsbad
I have similar issues. Also pump revving up and down while using water. I tried this and found filter/screen was a little loose. It seemed to help but I need another weekend out to test again. This adjustment really helped the revving of the pump while in use. I had asked dealer about this revving, they said it was normal. I knew otherwise. It just took me a few years to find an answer.
http://www.doityourselfrv.com/adjust...lo-water-pump/
thanks to doityourself RV!
03-09-2019, 09:37 AM
Gulf Breeze
My pump is a FlowJet. I don't have the model number but it looks like the "Flojet 2.9 GPM 50 psi Water Pump". It's in a very awkward location and would be a PITA to replace but doable. We are going on a trip next week and I will be able to monitor more closely what is going on. But I do appreciate your offer. If I did go through the trouble of removing I would probably replace with a much quieter one. The problem should not interfere with our trip unless it starts running at 2am.
03-09-2019, 09:45 AM
Gulf Breeze
Thanks for the link. I watched the video and it does not appear I have the same problem. My pump works fine without revving in normal use. If I leave the pump on for an extended time I lose prime and the pump runs. I will investigate further when we go on our trip next week. Intermittent problems are tough to track down.
03-10-2019, 05:13 AM
Auburn
, Georgia
You didn't mention checking the toliet valve. I had the pump running as you described and it was the toliet valve was causing it. A few flushes and it cleared the problem.
03-10-2019, 07:15 AM
2009 27' FB Flying Cloud
1982 31' International
1991 35' Airstream 350
Jay
, Oklahoma
I agree with your “lost prime” theory.
Sounds like the bowl of the strainer is not sealed and alllowing the pump to suck air.
Perhaps a little Teflon plumber’s dope on the o ring.
Regards,
JD
Jeff & Cindy
'09 27FB Flying Cloud;'82 31 International
'91 350 LE MH; '21 Interstate 24GT
03-10-2019, 08:48 PM
2023 Interstate 19
Colorado Springs
Check to make sure the sink lid is not in contact with the small valve handle. If left up, the lid can activate the valve when you close the lid. Just saying.
03-11-2019, 09:00 AM
Gulf Breeze
I will definitely check that. Thanks.
03-11-2019, 09:04 AM
Gulf Breeze
Sounds like the bowl of the strainer is not sealed and alllowing the pump to suck air. Perhaps a little Teflon plumber’s dope on the o ring.
Regards, JD
I did do this along with flushing the toilet a few times and waiting to see if that either did the trick . Thanks
03-11-2019, 09:06 AM
Gulf Breeze
I know about the little issue but thanks for reminding me.
